01-26-2015 07:03 PM
52 123
tools
  1. heraldo's Avatar
    Same issue with my galaxy s4.
    Sent from my SCH-I545 using Tapatalk
    11-04-2013 10:35 PM
  2. gonwan's Avatar
    The latest update has fixed the issue on my note 3 (SM-N9005)
    11-05-2013 07:02 PM
  3. zmann's Avatar
    What update was this? The latest update did not fix I t for me.
    THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
    11-05-2013 07:28 PM
  4. gonwan's Avatar
    This software update was only a small one, about 88MB and I did it yesterday.
    Baseband: N9005ZHUDMJ4
    Build: JSS15J. N9005ZHUDMJ4
    Kernel version:
    3.4.0-1942266
    se.infra@R0301-14#1
    Fri Oct 25 17:06:58 KST 2013
    11-05-2013 07:38 PM
  5. ejdavis72's Avatar
    gonwan, will you please post your camera apk so I can fix my Galaxy S4 with it? Thanks I'd really appreciate it.
    11-05-2013 10:03 PM
  6. gonwan's Avatar
    My device is not rooted, where is the apk located?
    11-06-2013 01:42 AM
  7. Adrgha's Avatar
    Same issue here after updating to 4.3 on my S4. This is actually driving me nuts. I bet we'll have to wait for 4.4 for this to be fixed. Grrr!!
    11-06-2013 07:44 AM
  8. pdub73's Avatar
    I thought I saw an update a few days ago but it wasn't there maybe it is now...
    Sent from my SM-N900V using AC Forums mobile app
    11-06-2013 08:07 AM
  9. pdub73's Avatar
    I updated to MJ7 the transition animation bug still exists...nothing else has changed either, I'll see if the sound quality is improved or not later
    11-06-2013 04:49 PM
  10. ejdavis72's Avatar
    The samsungcamera2.apk is located in system/app but you have to be rooted to get it
    11-07-2013 01:18 AM
  11. Flip Jumpman's Avatar
    Same issue with the camera defaulting back to 1x. Recent update (AT&T) did not fix the problem...
    GALAXY Note 3 via Tapatalk
    11-18-2013 10:03 PM
  12. eulmer24's Avatar
    UGH!!! VZ S4 here and this is miserable; the phone truly runs significantly slower when the animation scale is set to 1x... It is the worst changing it back every time we use the camera.WHY CANT THEY FIX THIS NONSENSE?????? Has anyone figured out a way around it other than not using the camera?
    -Eric
    11-25-2013 11:41 AM
  13. pdub73's Avatar
    -Eric
    I wonder if our concerns are even reaching the right people... It's clearly an issue with Android 4.3 because before I upgraded my wife's S4 to 4.3 she did not have the issue... my Note3 had the problem right out of the box...
    11-26-2013 05:07 AM
  14. Eric Mazariegos's Avatar
    Same annoying issue here as well. I really hate touch wiz so disabling the Window animations really helped ameliorate that but this bug really irks me to new extents... I'm on tmobile and using an unrooted GN3
    12-15-2013 12:19 PM
  15. anthonok's Avatar
    Funny. Mine is the opposite. It randomly changes back to off. AT&T note 3 here. I prefer the animations so it really bothers me when I hit home and it just instantly goes home without a nice animation.
    01-25-2014 07:55 PM
  16. marciedonato's Avatar
    You have to tap the build number about 5-10 times and developer mode opens up.
    02-21-2014 12:04 PM
  17. 11Drogba's Avatar
    Try this: unisntall whatsapp, and then install whatsapp plus or whatsapp+.
    I don't know what relation whatsapp plus has with transition scale when opening camera, but it worked.
    Folks please report back if it works for you.
    06-18-2014 09:38 AM
  18. Mark Verhagen's Avatar
    Finnaly i have found a solution guys to fix this annoying problem. 1st you need to download "App Ops Starter" apk from the play store. After opening it go to the camera app and disable the permission that wants to modify settings. Leave the app and no more annoying animation scale bug.
    07-08-2014 04:04 AM
  19. jpr's Avatar
    KitKat fixed the bug. No need to screw up your camera.
    07-08-2014 04:07 AM
  20. Mark Verhagen's Avatar
    Kitkat did not fix it for me. It's the opposite with kitkat, it disables the animation on itself and i'm one of the few persons that actually likes animations. So for me the camera kept breaking the animation and i needed to turn it on every time in the dev. options.
    And by turning off the permission for the camera nothing breaks, everything keeps on working perfect like it used to.
    07-08-2014 04:20 AM
  21. jpr's Avatar
    What model phone do you have? That absolutely does not happen on mine - N900T.
    07-08-2014 04:31 AM
  22. Mark Verhagen's Avatar
    I'm using the N9005 international version unbranded.
    07-08-2014 04:38 AM
  23. jpr's Avatar
    Is that before or after the recent NF4 build update?
    07-08-2014 04:50 AM
  24. Mark Verhagen's Avatar
    I'm still on the END3 version. I'm rooted so i cannot take the OTA updates. And since i'm on holliday i don't have access to a PC so i have to wait to update. So yeah if the new update fixes the problem than my "fix" is not needed anymore.
    07-08-2014 05:05 AM
  25. Jalopiejoe's Avatar
    KitKat upgrade fixed that problem on my Note 3! 👍
    Sent from my Samsung Galaxy Note 3
    "Size Does Matter!"
    07-09-2014 08:52 AM
52 123
  1. Galaxy Note 3 - Note 2 to Note 3 Transfer
    By mayfieldh in forum Samsung Galaxy Note 3
    Last Post: 05-15-2014, 06:06 AM
  2. could the note 3 be the phone im looking for?
    By RavenSword in forum General News & Discussion
    Last Post: 10-03-2013, 01:43 PM
  3. Galaxy S4 Charger/Cable Not Working - Help!
    By MrGalaxyS4 in forum Samsung Galaxy S4
    Last Post: 10-02-2013, 02:27 PM
  4. Switching From Note 2 to S4 Question
    By chuckawd in forum Verizon
    Last Post: 10-02-2013, 10:56 AM
  5. Replies: 0
    Last Post: 10-02-2013, 07:40 AM
