1. ska916jedi's Avatar
    Hey guys, one reason I don't like Android devices because they don't have a thing like iTunes that always backsup your phone. My Q is, how would I transfer my Note 2 stuff to my 3? I see there's a backup option under Settings. Would I do that and it saves to my SD Card? I don't use Google mail so I don't want to backup using that if that's an option. Suggestions? Thanks!
    10-04-2013 09:45 AM
  2. JoeyyNY's Avatar
    I backup/Restore all my stuff with Google... It's so easy...
    Sent From My Lighting Fast Galaxy Note 3 & Galaxy Note 8.0.
    10-04-2013 09:49 AM
  3. JoeyyNY's Avatar
    Blah sorry I just woke and did not read clearly that you do not use Google Mail but its worth trying..
    10-04-2013 09:52 AM
  4. SpookDroid's Avatar
    Fair enough, but the thing is there IS an iTunes equivalent... Actually, a ton of them. Your phone is always backed up either in Samsung's S-Cloud or in Google's (and years before iCloud happened); of course, you have to enable it for this to work. If you own an Android, you should have created a Google account at some point, even if you don't use GMail.
    Your apps, just like iTunes, are always 'saved' in Google Play. When you sign in to a different device with the same Google ID (same as with Apple ID), your phone will sync and will re-install all your downloaded apps and purchases (which is why I suggest you always do the phone's setup while on WiFi if you don't want to blow through your data allowance in a day).
    Now, as for music and pictures and documents, you have Samsung's "iTunes", called Kies. Or you can use another software of your choice like MyBackup or the always popular Titanium Backup. These apps will let you transfer most of your phone's data over SD card or Dropbox sync. The advantage with these is that it also saves app data and preferences, but I find that's it's always smoother to just do a 'clean' install of every app in every new device (yes, even in Apple stuff). But that's up to you.
    ska916jedi likes this.
    10-04-2013 09:58 AM
  5. ska916jedi's Avatar
    Thanks guys. I of course had to make a Google account to use the store, but don't use it for mail because I've been using the old school Hotmail since the mid / late 90s. LoL Anyways, when I switched to the Note 2 from the iPhone 4, I logged in my Google mail and it screwed up all my contacts that I transfered with an app from the 4. Mt contacts are still kind of messed up and didn't want to deal with bs again. I hope that makes sense.
    10-04-2013 04:24 PM
  1. Using Google Docs/Drive/Keep on Note 3 (Are you disappointed?)
    By AgentScribe in forum Samsung Galaxy Note 3
    Last Post: 10-16-2013, 08:43 PM
  2. How to know if current ROM is stock?
    By krad0000 in forum General Help and How To
    Last Post: 10-07-2013, 11:23 PM
  3. Moto Skip Question
    By asylvia in forum Moto X
    Last Post: 10-07-2013, 08:44 PM
  4. Note 3 kit still taking ages to arrive..
    By thegame161 in forum Samsung Galaxy Note 3
    Last Post: 10-04-2013, 09:21 AM
  5. Replies: 0
    Last Post: 10-04-2013, 08:15 AM
