1. ttexxan's Avatar
    Purchased Note 3 from Best Buy today and noticed right away the back of the unit near camera very warm. Coming from a Note 2 did not notice the warmth when charging unit. My note 3 is extremely warm while charging as well. I did a factory hard reset and still occuring? Wondering if I should exchange. Anyone else notice device becoming hot
    10-04-2013 10:52 PM
  2. Wayne Gingell's Avatar
    Mine did the same until I did the following. Updated software for phone. Removed battery and sd card. Then put it back together. Cooled off right away
    10-04-2013 10:56 PM
  3. ttexxan's Avatar
    Have you noticed any other issues with overheating though?? Its seems to cool down quickly, but seems to get hot when scrolling and downloading apps as well.
    I find the upper back portion of the phone warm where the lower part not at all. Area around camera.
    I dont mind toying with it, but somewhat new to android platform. Only reason I state this is inquiring if possible to back up all apps and then reload without tediously going through the store to do so if doing another hard reset. Can you back up to home computer or does it require memory card in phone.
    10-04-2013 11:01 PM
  4. Golfdriver97's Avatar
    Welcome to the forums!
    I would contact Samsung at least. If not Verizon. This doesn't sound normal.
    10-04-2013 11:03 PM
  5. ttexxan's Avatar
    After taking out the battery and sim card and reboot it seems to be doing better now. I didn't have an update to download. Not nearly as warm now
    10-04-2013 11:52 PM
  6. Botti's Avatar
    Cpu is there. Don't worry, the gigahertzes just won't come for free.
    Adamsberg and gdmin like this.
    10-04-2013 11:57 PM
  7. Adamsberg's Avatar
    Yep, actual phones' CPUs have allowed temperatures up to 90C (194F).
    10-05-2013 04:07 AM
  8. mavrrick's Avatar
    I noticed mine getting warm yesterday under certain loads. It will happen from time to time. The cpu's in these things will produce some heat when fully ramped up. The phone should also throttle it if it gets to hot.
    10-05-2013 05:35 AM
  9. zmann's Avatar
    So far I have not experienced any overheating but I will keep an eye on it.
    THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
    10-05-2013 05:53 AM
  10. Melinium's Avatar
    some oveheating the first day of use, maybe the SFind indexing things in the background
    10-05-2013 07:16 AM
  11. archer75's Avatar
    Mine got warm the first day while I was setting everything up. Since then I haven't noticed it.
    10-05-2013 07:56 AM
  12. ttexxan's Avatar
    Just an update been using this am without over heating working great
    Sent from my SAMSUNG-SM-N900A using Tapatalk 4
    10-05-2013 08:24 AM
  13. vinay kumar21's Avatar
    I am facing the same problem , did u find any solution?
    08-07-2014 09:38 PM
  1. Google Now and Note 3 Question
    By MaTtKs1 in forum Samsung Galaxy Note 3
    Last Post: 07-11-2014, 11:10 AM
  2. Any ETA on 4.3 Update for Verizon Galaxy Note 2?
    By jarod radigan in forum Verizon Galaxy Note 2
    Last Post: 10-26-2013, 12:22 PM
  3. Can The Note 3 Be Used With One Hand?
    By music_man185 in forum Samsung Galaxy Note 3
    Last Post: 10-07-2013, 02:28 AM
  4. White and black Note 3 are different!
    By Chris Nguyen2 in forum Samsung Galaxy Note 3
    Last Post: 10-05-2013, 11:12 AM
  5. Note 2 video issues
    By mortalmallard11 in forum Verizon Galaxy Note 2
    Last Post: 10-04-2013, 11:49 PM
