1. Quad150db's Avatar
    Not sure is this is common knowledge but when going through the camera settings I noticed that you have the option to turn off the shutter sound.
    No phone I've had in the past few years has had this option without root or some other work around..
    diasmall likes this.
    10-06-2013 07:24 PM
  2. TeamPowerstroke's Avatar
    I had the option on my Galaxy S4 also..
    Tappin From My N3
    10-06-2013 07:26 PM
  3. Quad150db's Avatar
    I never had the s4 I went from s3>Note 2>Note 3
    I am glad to see samsung including this feature now.
    10-06-2013 07:34 PM
  4. MaTtKs1's Avatar
    Not seeing this option. Carrier specific perhaps? I know that option was removed via update with my Sprint Note 2.
    10-06-2013 07:45 PM
  5. Quad150db's Avatar
    I have a tmobile phone. Once you in the settings dialog go to the list on the right side is at the bottom of the list.
    10-06-2013 07:56 PM
  6. BeRich's Avatar
    It's carrier specific. My S3, Note 2, and Note 3 all had/have this option even without rooting. IIRC, Sprint is one of the carriers that doesn't allow for muting the shutter sound in order to protect the privacy of others.
    10-06-2013 08:19 PM
  7. candycakes525's Avatar
    That's a fail and control thing with Sprint. You can simply mute the shutter sound by muting the phone.
    10-08-2013 08:06 AM
  8. Almeuit's Avatar
    Not true with the previous versions.. Even if the phone was muted it would still click.
    Sent from my T-Mobile HTC One using AC Forums.
    10-08-2013 08:20 AM
  9. rkopsie's Avatar
    my DROID phones and my S4 allowed you to turn it off.....
    10-08-2013 11:09 AM
  10. Quad150db's Avatar
    I was a sprint user for years and didn't even realize it was specific to them
    10-08-2013 02:54 PM
  11. Rachel Smith2's Avatar
    Where do you do this?
    Up until now, I have had iPhones and before that it was Nokia.
    I have always had this option.
    Can seem to find it in my Note3 though.
    Also, how do I change my email address in the play store?
    12-09-2013 11:01 PM
  12. stackberry369's Avatar
    You can turn the phone volume down and the shutter sound will be off when you take a picture
    12-09-2013 11:34 PM
  13. Rachel Smith2's Avatar
    Tried that. Doesn't work.
    12-10-2013 12:30 AM
  14. JellyBeanGurl's Avatar
    My phone is on mute and it worked.
    Sent From My Samsung Note 3 using Tapatalk
    12-10-2013 12:58 AM
  15. Gearu's Avatar
    (With root) You can replace the original click sound files with silent ones (I didn't try deleting altogether) and this does silence it (it doesn't seem to at first as you still hear the click sounds).
    It just takes time for the change to occur even after a switch off/on.
    12-10-2013 05:17 AM
  16. dcamjones's Avatar
    Verizon does not allow for that. Didnt allow it on my S3 either. TMobile does though.
    Camera FV app will mute it though in app
    12-10-2013 07:07 AM
  17. pdub73's Avatar
    My Verizon note 3 doesn't have the option to turn it off but I put my phone on vibrate and the shutter is silent
    Sent from my SM-N900V using AC Forums mobile app
    12-10-2013 10:28 AM
  18. Behzad Ravanbakhsh's Avatar
    turn phone volume down then the shutter sound will be silent when you take a picture
    Or
    Download And install http://forum.xda-developers.com/show....php?t=2502522
    msndrstood likes this.
    03-02-2014 03:54 PM
  19. dpham00's Avatar
    You can use an app like "enforced stream silencer". Just Google it
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    03-02-2014 09:00 PM
  1. Note 3 screen freeze
    By rohit 51 in forum Samsung Galaxy Note 3
    Last Post: 08-29-2015, 06:34 PM
  2. A&t Note 3! Only 5 of the 12 Camera Modes?
    By Misparkle8shine in forum Samsung Galaxy Note 3
    Last Post: 04-11-2015, 10:11 PM
  3. Sony Xperia Z - Individual Contact message sounds?
    By Michelle Panton in forum Sony Xperia Z
    Last Post: 01-13-2014, 08:56 AM
  4. How to get 4.1.2 camera effects on my 4.0.4 camera
    By patsum in forum Verizon Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 10-06-2013, 11:42 PM
  5. T-Mobile Note II and AT&T GoPhone Sim.
    By Chris Pawlowski in forum Samsung Galaxy Note 2
    Last Post: 10-06-2013, 03:45 PM
