It has the WCDMA only and GSM only option. But no LTE only option. Help!
Sent from my SM-N9005 using Tapatalk 2
Too bad.
The constant change from 4g to 3g is draining my batter.
That's a carrier issue than not your phone. If it's bouncing back and forth that's due to a weak 4g signal. If you could lock onto the 4g signal only your battery would plummet more since it sounds like a super weak signal already.
Sent from my T-Mobile HTC One using AC Forums.
Yeah. Usually 1 bar. But still. It's faster. Haha. I usually download big files while at work. But guess I'm stuck with 3g for now.
What carrier? Just curious.
Sent from my T-Mobile Note 3 using AC Forums.
hey here is an app you can use to lock the note 3 to lte only its called "Advanced Signal Status" i use it on my Note 3 https://forums.androidcentral.com/e...ils?id=com.cc.signalinfo&hl=en&token=ypBgM56o
dear
this code *#*#4636#*#* is not working on Note III
any one can help us to change the network to LTE via a secret codes of Samsung
