So how exactly do you use the TV remote function on this beast?
Sent from my SM-N900V using AC Forums mobile app
Printable View
Load the app called Watch On.
It's rather slick, you enter your zip code and your provider (local broadcast, cable provider etc) You then program your device (TV or cable box) via the on-screen instructions. It then gives you tiles on your phone with what is playing. Lets say it's 7:00pm, it'll show you a thumbnail of all the shows currently on, you click the show you want to watch and it changes your TV or cable box's channel.
