I've been wondering this every since I found out what this mode does
CPU power saving: Limit the maximum performance of the CPU to conserve battery power.
Screen power saving: Use a low power level for your device's screen to conserve battery power.
Turn off haptic feedback: Turn the haptic feedback option off to conserve battery power.
How much does this feature slow down the cpu and how much does power do you save from that
Also I herd the screen power saver lowers screen refresh rate which lowers power kind of like what Lg G2 says their graphics ram does
If someone has a way to test this let me know your results and have you had any noticeable change in performance using this feature
