1. ttexxan's Avatar
    I have s view case with the weather option turned on when s cover closed. However my temp stays the same never changes on s view. Any ideas??
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    10-13-2013 09:40 PM
  2. jamesish's Avatar
    Is anything updating? Also what input did you choose, accuweather?
    Sent from Samsung Galaxy Note 3 now Free
    10-13-2013 09:52 PM
  3. ttexxan's Avatar
    The weather is the only thing not updating for some reason. Didn't see a choice on weather app to choose in settings. Think it's going off of weather bug
    10-13-2013 09:59 PM
  4. alp1917's Avatar
    Either refresh it manually on the phone or set the update interval to 15 minutes
    Sent from my Galaxy Note 3 on Verizon now Free
    MaTtKs1 likes this.
    10-13-2013 10:02 PM
  5. jamesish's Avatar
    Mess with your sync settings and see what happems. Reset all syncing meaning toggle off and on.
    Also don't feel insulted but dud you reset the device. Turn off and back on.
    10-13-2013 10:03 PM
  6. karsdroid's Avatar
    you cant choose a specific weather app i dont think, but click on the weather toggle under the s view settings in the accessory settings and you can choose how often it refreshes....the default is 6 hours which is too crazy long....the shortest on mine is 1 hr....
    10-13-2013 11:41 PM
  7. zef05's Avatar
    it updates On mine...
    yeah, try to check your syncing options and I Guess data needs to be on or something
    Sent from my Samsung Galaxy Note 3 - SM-N9005 using Tapatalk 4
    10-14-2013 01:30 AM
  8. AndyLu's Avatar
    You have to go to settings > lockscreen > select info shown cover > make sure the weather setting is on.
    Select weather and turn on auto refresh
    There are hour intervals
    Hopefully that helps
    DINGSTER1 likes this.
    10-15-2013 10:58 PM
  9. ibill1's Avatar
    maybe a dumb question but how do you turn on the weather option?
    10-16-2013 12:01 AM
  1. Help Pls Weird Problem with Phone
    By Tina3882 in forum General Help and How To
    Last Post: 12-26-2015, 08:04 PM
  2. Replies: 2
    Last Post: 01-20-2014, 04:30 PM
  3. Stop with the giant phones
    By DS1331 in forum General News & Discussion
    Last Post: 11-17-2013, 10:46 PM
  4. Please Help
    By Gage Crosswhite in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 10-16-2013, 12:14 AM
  5. Replies: 2
    Last Post: 10-13-2013, 09:56 PM
