Has anyone noticed this? I get a sound and when I check my notifications there is nothing there! And sometimes it will chime 3 or 4 times in a row with nothing on the notification. Is there a way to fix this?
the first few days I had the Note, it was doing that too. I'd get the notification sound but nothing in the notifications, it drove me nuts. I finally traced it to something.... I think it was a newswatcher or something and it was auto set to sound an alarm whenever there was a new entry. Sorry I can't tell you the name of it, I couldn't figure out how to un-set the alarm so I just uninstalled the whole annoying thing. Anyway, it's probably not the same app, but maybe the same circumstance? Anything new that might be triggering it?
Has anyone noticed this? I get a sound and when I check my notifications there is nothing there! And sometimes it will chime 3 or 4 times in a row with nothing on the notification. Is there a way to fix this?��
i'm finding that this happens when i get an email in my gmail "promotions" tab or "social" tab. since they aren't my main inbox they don't show up in the notification panel .....it is a tad irritating....
Is it doing it when it might be trying to go back and forth between two wi-fi's? I can remember mine doing that and just looked at my settings. I turned off the network notification setting that says when an available wifi is present. At home I have a range extender and it split up my house wifi and there was a lag when it was trying to figure out which one of the maximum strength signals to use. Now I just keep it on one and it's fine.Ok...so I just made an observation while my phone was chiming its life away. The AT&T thats on the top left of the notifications kept appearing and disappearing. Wth? Why is it doing this? Everytime it appeared and disappeared it was chiming. SMH.
alright guys this is happening to me also and i hate it but i work in a job where i hook up my phone and it sits next to me all day, so when it was giving the notifications its always been plugged in and i think its a bug because i see that it disconnects form charging then starts back up a second later so the notification is the charger connecting again, not sure if this problem is when your charging your phone but if it is then thats it......i know its not just mine because my GF note 3 does the same thing. hope this helped
Actually when I noticed it today the AT&T letters on the top left in the notifications disappeared. Im stumped as to whats going on? No problems when charging it. Wait. I think it has done it while charging too. �� Make it stop!! ��
