10-25-2013 05:05 PM
31 12
tools
  1. CehowardNote7's Avatar
    On the Note 3, and several other Samsung high end smart phones, it has this "GREAT FEATURE" of a
    removable battery..This feature here was almost a game changer for some, and a definite boost in the usability of the phone.
    However, in all the threads, and there are many of them, all I see is "battery usuage" or how long you getting out the battery, along with
    a ZILLION screen shots of users who have saved or not saved battery power. However, nothing, almost nothing on swapping out batteries, when you
    run out, and even more important (the topic of this thread)the different types and brands of replacement batteries..
    From what I been reading here, Samsung could have made the battery non-removable, and just added some more juice, and it seems the majority
    would be happy, because nobody is talking about swapping the battery out, and different aftermarket batteries..
    I am going to used the removable battery option big time. On trips carrying a spare battery or two, along with a charger that stands alone with the battery. I am seeing different types, and prices..
    1st choice
    Amazon.com: Hyperion Samsung Galaxy Note 3 ALL Models 2 x 3200mAh Battery + Charger **NOW WITH NFC/GOOGLE WALLET** Compatible with AT&T / T-Mobile / Sprint / and Verizon Samsung Galaxy Note 3 and International Samsung Galaxy Note III N7200 Models [2
    2nd choice
    Babo 4500mAh High Capacity Battery for Samsung Galaxy Note 3 N9000 N9005 N900 | eBay
    3rd choice
    3X 3500mAh Battery Charger for Samsung Galaxy Note 3 III N9000 N9005 N7200 US | eBay
    Anybody using any of these and are their others replacement batteries?
    I am not into that extended battery where you need a bigger case..
    dragonsamus likes this.
    10-15-2013 07:07 AM
  2. Haalcyon's Avatar
    Some may use this feature. For me it's more of a knowing that if I wear the battery out I can replace it. However, in reality, I probably won't have the phone that long. I'm never that far away from a charger for long.
    10-15-2013 07:26 AM
  3. thegame161's Avatar
    It's very useful for me when getting home then going out. Just having the option is great. I normally charge mine overnight but when it doesn't need doing least I have my spare with me when it's needed later that day
    10-15-2013 07:33 AM
  4. penningtonsm's Avatar
    I am of the opinion that no phone has an adequate battery for all day use if you are a heavy user. That's why, in my humble opinion, I will always get a phone that has a removable battery!
    Sent from my LG-E980 using AC Forums mobile app
    10-15-2013 07:55 AM
  5. tippmann15's Avatar
    I can't even find the extra battery at the Samsung site or I'd have 2 already.
    Note 3 <Caesars>
    10-15-2013 08:14 AM
  6. kanundrum17's Avatar
    Don't buy cells that are made in china, you don't know when they will over heat. Always buy trust source cells like Seidio (japanese) etc
    Timothy Cuevas likes this.
    10-15-2013 08:30 AM
  7. CehowardNote7's Avatar
    Now, that is a good point and what I was looking for. Feedback on aftermarket batteries..
    Just checked with Seidio and all their batteries are for the Note 2 and S4, nothing yet for the Note 3.
    10-15-2013 08:51 AM
  8. AuburnGrad's Avatar
    I think with as new as the phones are, most people are not having an issue with the phones not holding a charge long enough. It will come in 6 months time, when some might not last as long, as they would like under heavy usage. I will have it for travel, but waiting on the Samsung battery and charger station to get in stock.
    10-15-2013 09:22 AM
  9. dragonsamus's Avatar
    I remember back when the incredible was brand new. Seidio released a 1700 mAh slim battery for it that was the same size as the stock 1300 battery. Turns out Seidio was lying and their 1700 battery was just a 1300. Since then I never trusted them.
    I would love an extra battery but I'm not sure which one to get.
    Sent from my SM-N900T using AC Forums mobile app
    10-15-2013 09:27 AM
  10. Deaj's Avatar
    Question:
    There are Samsung labeled OEM batteries (Samsung part # B00BE) being manufactured in China. Are these to be avoided as well?
    10-15-2013 10:16 AM
  11. power5's Avatar
    I cannot believe those Babo are 4500mah. If it was possible to squeeze that much into the stock size battery, why would samsung have only gone with a 3200?
    10-15-2013 10:21 AM
  12. ttrain68's Avatar
    Battery life on this phone seems great, but I use and use and use especially when I am not home so I ordered the below before I even received the phone. Even if they are not great I'm sure they will do in a pinch and at 7 bucks, seemed like a no brainer.
    Caseology 2 X 3200 mAh Li-ion Replacement Battery for Samsung Galaxy Note 3 with Travel Wall Charger with USB Port (Non-NFC) [18-Month Warranty] Caseology 2 X 3200 mAh Li-ion Replacement Battery for Samsung Galaxy Note 3 with Travel Wall Charger with USB Port (Non-NFC) [18-Month Warranty]
    Sold by MODN Mall.
    Below is a link to reviews for the replacements for the Galaxy S3.
    Caseology 2 X 2100 mAh Li-ion Replacement Battery for Samsung Galaxy S3 with Travel Wall Charger with USB Port (Non-NFC) [18-Month Warranty]
    10-15-2013 10:27 AM
  13. penningtonsm's Avatar
    I bought a hyperion battery for my lg Optimus G Pro that started out well, but after a few weeks it drops to 69 percent as soon as I put it in. Then drops very quickly thereafter. So I purchased the zerolemon battery (9300mah) and never looked back.
    fkpalm likes this.
    10-15-2013 10:35 AM
  14. CehowardNote7's Avatar
    Same here, that is why I started the thread. That is to get a idea on what is the best replacement battery.
    10-15-2013 10:53 AM
  15. Haalcyon's Avatar
    Question:
    This is a question, not a statement: Are all Samsung OEM parts only made in Korea? Are none supplied from China or Taiwan so as to raise the above question?
    from my '14 Note 10.1
    10-15-2013 11:02 AM
  16. dragonsamus's Avatar
    Personally, I wouldn't trust a company claiming they packed in more battery power into the same size of a smaller battery. So if the 4500 batteries are the same size as the 3200 then they're probably lying. If they are larger than there's a good chance it's true.
    10-15-2013 11:09 AM
  17. CehowardNote7's Avatar
    Hoping I can hear some experiences on using that battery.. Seems too good to be true. A good 20% more, 2 batteries and a charger for that price...
    10-15-2013 12:00 PM
  18. CehowardNote7's Avatar
    That is an extended job isn't it?
    10-15-2013 12:02 PM
  19. penningtonsm's Avatar
    If by extended job you are talking about the life of the battery, then yes. I easily get ten hours of screen on time with a little battery still left over. Screen on time is the only way I measure battery life because it Matters not to me if you can get 72 hours of battery life by not using your phone. How many hours can you get out of it if you actual use it for the purpose the phone was designed for? Big screen, 1080p resolution and fast UI. Requires the screen to be on to marvel at those things.
    Sent from my LG-E980 using Tapatalk 4
    10-15-2013 12:50 PM
  20. CehowardNote7's Avatar
    No, by "extended" I mean is it oversize, needing a aftermarket oversize back cover. Most stronger than stock batteries for cell phones are bigger and come with the accessory large back cover. Not wanting to go there. I like the slimness and the standard size...
    10-15-2013 12:53 PM
  21. penningtonsm's Avatar
    Yes the battery does come with a case that adds some girth to it. It's no longer slim by any stretch h of the imagination. However the one hand functionality of the device doesn't go away. I can do the same one handed operation as I could with the original battery. I can just do it three times longer. Well worth it to me as I am a habitual user.
    10-15-2013 12:56 PM
  22. GtoJon's Avatar
    I did order the Caseology 2x 3200 batteries. I was going to wait for Anker, but that may be forever! My Anker batts for my Note 2 would read 100% for 2 hours after putting them in & would last me up to 6 days .... really, not a heavy user! Some of those batts that say 3500, 4500 or higher ... is bogus! Another note, some of those batteries that have Samsung Batteries are absolute junk!!! They would start out at 93% & some would even fall off like a rock (20 minutes) after 49%!
    Beware & be careful .... I and others will report here after our findings .... too bad it will be a couple of weeks before they ship
    Cheers, Jon
    10-15-2013 01:09 PM
  23. CehowardNote7's Avatar
    Cheers, Jon
    In searching around, I found out that this battery won't have NFC compatibility, but for that price, and if it works 95% of the stock battery, and the charger charges the OEM battery, sounds like winner.. I just read some reviews on the Hyperion 2x3200 + Charger, and they said the batteriers work, not as strong as OEM, no NFC, and maybe about 90% as strong as the OEM. The charger takes about 7 to 8 hours to charge too. These Hyperions cost about $35 shipped, that is almost double to the Caseology with the 2 batteries and charger.. Think I will go with the Caseology for 2 reasons. Price is cheap, and they are just when I take trips, or really stuck out there.. Just like people always carry a spare tire, I am carrying a spare battery.
    ttrain68 likes this.
    10-15-2013 01:42 PM
  24. iPhone 5_to_GS4's Avatar
    I need these
    Sent from my SM-N900V using AC Forums mobile app
    10-15-2013 05:08 PM
  25. Sooks's Avatar
    I would be very impressed if you couldn't get all day use out of a Razr MAXX or a Note 2 / 3 ... I would considerer myself a VERY heavy phone user and I can always make it through one day on these devices.
    10-15-2013 05:14 PM
31 12
  1. Stuck in Factory Mode
    By jaymes13 in forum Samsung Galaxy S II Skyrocket
    Last Post: 06-25-2018, 05:21 AM
  2. Replies: 5
    Last Post: 10-17-2013, 02:18 PM
  3. Any way to go full bright in direct sunlight (automatically)?
    By snc0921 in forum Samsung Galaxy Note 3
    Last Post: 10-15-2013, 07:28 PM
  4. Replies: 2
    Last Post: 10-15-2013, 09:49 AM
  5. Multiple Locations in Google Maps
    By neil154 in forum The Android Central Lounge
    Last Post: 10-15-2013, 08:21 AM
