1. XCB1995's Avatar
    Hi everyone im new to the forums and recently got my note 3 last week on Thursday. I have the Tmobile version.
    An issue that I am having is that my battery dies qquicky. I don't know if this has something to do when I first got the phone because I didnt charge it once I had got the phone and once I did get the phone I factory reseted it so that I could go through the initial setup (you know the menus that tell you to put your language, wifi, gmail etc.)
    I have everything turned off I have my brightness always set to 0 I don't use auto brightness. I only increase the brightness when im outside in the sun. I have auto syncing completley turned off I only have notifications from apps such as Facebook, instagram and other apps.
    I Don't have anything running in the background nor do I have any wakelocks happening.
    I also have power saving mode on, the only thing thats enabled is the lower cpu option.
    When i got home i decided to drain the battery to where the phone turned itself off. I then pluged it in to charge and i turn the phone on while it was charging and left it there untouched until it fully charged.
    Once it was done i unpluged it and started using it. I updated 3 apps, i went on facebook and instagram for a quick bit and used chrome for about 10 or 15 mins and my device is at 95%, and has been on for 37 mins with 32 mins of on screen time. I dont thinks that normal.
    On saturday i was using chrome starting around 11 am and it lasted 8 hours with 5 and half hours of on screen time is that normal?
    10-15-2013 11:49 PM
  2. Chris Nguyen2's Avatar
    That seem about right, what did you expected the battery life to be?
    10-16-2013 12:37 AM
  3. TeamPowerstroke's Avatar
    so we will say every 5% = 30 mins. 10% gets you 1 hour of screen time.Comes out to 10 hours of screen time.. That doesn't sound good? lol
    10-16-2013 12:42 AM
  4. XCB1995's Avatar
    Well i thought maybe it would last a bit longer cuz i thought the battery was decreasing quickly. Is this how your device battery is?
    10-16-2013 12:47 AM
  5. XCB1995's Avatar
    Well im coming from an LG motion which had a 1700 mah battery and tge phone had an Android OS issue. It was always the highest thing that was using up the battery, and it would never last me.
    I expected the note 3's 3200 mah battery to not decrease that quickly but im probably so used to the Motions battery i just assume that this isnt normal.
    But of course this phone has higher specs than the motion and im probably juss being picky about the battery lol.
    10-16-2013 12:53 AM
  6. Chris Nguyen2's Avatar
    Then again I never really tested my battery but it a lot better than the S4. I was playing Dungeon Hunter 4 for six hours and still had 15% battery left but I never use max brightness.
    10-16-2013 01:58 AM
  7. clevin's Avatar
    Its normal, and its good.
    10-16-2013 05:46 AM
  8. Almeuit's Avatar
    Normal.
    Sent from my T-Mobile Note 3 using AC Forums.
    10-16-2013 08:12 AM
  1. Where the Heck Are the S view Cases?
    By infenit101 in forum AT&T Samsung Galaxy Note 3
    Last Post: 08-06-2014, 01:44 AM
  2. Replies: 1
    Last Post: 10-27-2013, 11:40 PM
  3. read email on the gear?
    By karsdroid in forum Samsung Galaxy Gear
    Last Post: 10-20-2013, 12:04 AM
  4. Feel bad for the lefties
    By the_stig#WN in forum Samsung Galaxy Note 3
    Last Post: 10-17-2013, 12:51 AM
  5. phone time date is messed up....
    By agmss15 in forum General Help and How To
    Last Post: 10-16-2013, 07:44 PM
