Interested in a smartwatch but unsure what to go with. Anyone able to compare the two?
Ended up with the gear although Sony's did look sweet
What made you decide for the Gear? I am on the fence on both.
Used the gear for a week, after a few days it became less fun and I found i was using it less and less.
What I like about the Sony Smartwatch 2 is its always on for 5-7 days, waterproof , and works on any android it also supports alerts for many more apps like gmail and facebook and twitter and so on. And it is 100.00 less, however I am going to be waiting tell the 31 to see if google announces their smart watch before I pick between the sony or the google watch (if there is one)
What was the Battery life ?
Say I started at 7am how long with medium to heavy use?
One thing that was very disappointing to me (and the reason I am sending it back) is that Sony's email app for the Smartwatch 2 (everything is handled through apps you download to the watch) does not work with the Note 3 or My LG G2. It says that they are unsupported devices. Go to the Play Store and look at the reviews for the app if that is important to you. It does not work with the GS4, the One or even the Xperia devices if the reviews are accurate. The Gmail app works as does the messaging app, but the lack of email was a deal breaker for me.
The gear is good, but I am not sure if I will keep it or not. It is pretty expensive for the functions I will use (email, messaging, etc.). Gmail does not work right and I do not see myself making phone calls using it or using it as a camera very often.
