1. browetally's Avatar
    Not sure what's going on but my N3 is starting to lock up and not let me swipe to unlock. Basically unresponsive. I'll wait a minute or so and then it comes back to life. Any way to diagnose this?
    10-17-2013 01:09 PM
  2. kenaconlon's Avatar
    Mine is doing the same thing hitting the power button (not rebooting) brings it back to normal...not happy hoping it's not a hardware issue
    10-18-2013 11:05 PM
  3. semp1's Avatar
    Same here. It's normal glitchiness. I notice it happens less when I don't use the stock text app. Just give your phone a restart.
    Posted via My Galaxy Note 3
    10-19-2013 12:36 AM
  4. crxx's Avatar
    Same here......
    Da NOTE 3!
    10-19-2013 12:41 AM
  5. bophead's Avatar
    I have noticed this too. I had to do a couple of battery pulls. I wondered if it was because I wasn't using the stock launcher.
    11-13-2013 07:15 PM
  6. XChrisX's Avatar
    I was trying to call someone the other day when my phone crashed, and since then I have been having this exact problem. Does anyone know if there is a fix for this?
    11-14-2013 07:52 PM
  7. crivera7836's Avatar
    this has happened to me tooo i hope they fix this
    11-14-2013 10:40 PM
  8. pathfinder3's Avatar
    I have not experienced this. Although I often Close All and clear memory through the Task Manager. Every now and then I'll run Clean Master and restart my device at least once a week.
    Sent from my VZW Samsung Note 3
    11-14-2013 11:58 PM
  9. lateralex's Avatar
    I'm having this exact issue, and needed to battery pull three days in a row. The power button isn't responsive, and taking the pen out gets the screen to come on but it will still be in unresponsive. I'm using action launcher pro, not sure if that is the issue?
    11-22-2013 07:23 AM
  10. Almeuit's Avatar
    Sounds like an app is crashing and you guys are having to wait for it to crash before the phone can respond.
    This happened with WatchON for me alot... I froze it with Titanium Backup and that resolved the issue.
    Sent from my T-Mobile Note 3 using AC Forums.
    11-22-2013 08:01 AM
  11. Robert Castillo Jr's Avatar
    I had this exact issue and researched It vigorously and finally found a solution. I realized when I uninstalled my 'app killer' app then the phone stop freezing. Hope this helps!
    11-25-2013 03:03 PM
  12. lateralex's Avatar
    How do you figure out what app is crashing?
    11-26-2013 07:23 AM
  13. SalixIncendium's Avatar
    I had an issue with Here and Now crashing. You might want to go into My Magazine and uncheck Here and Now and see if that helps.
    11-26-2013 08:11 AM
  1. asus me173x problem after os update to 4.2.2
    By stsaxon in forum ASUS MeMO Pad HD7
    Last Post: 04-21-2014, 09:13 PM
  2. Verizon LG G2 - Anybody got foxfi to work?
    By kris.richards in forum LG G2
    Last Post: 03-25-2014, 10:30 PM
  3. Sprint Galaxy S3 - What exactly is broken?
    By volcomgirl in forum Sprint Galaxy S III
    Last Post: 10-18-2013, 08:45 PM
  4. s4 to hdtv options
    By pjoseph in forum Samsung Galaxy S4
    Last Post: 10-17-2013, 08:15 PM
  5. [OLED] Screen Appreciation Thread.
    By Johnly in forum Samsung Galaxy Note 3
    Last Post: 10-17-2013, 01:27 PM
