1. icnmayhem's Avatar
    Is there a difference, other than being official and a lot more expensive, between the samsung wireless back and the off brand qi chargers they sell on amazon? Just wondering, since it seems like the samsung one replaces the entire back and is thicker. If the both work equally well, I'd just as soon get the cheaper one.
    10-17-2013 02:21 PM
  2. icnmayhem's Avatar
    10-18-2013 08:31 AM
  3. DCSholtis's Avatar
    I do not believe there is a difference at all.
    10-18-2013 08:59 AM
  4. icnmayhem's Avatar
    thanks, i may go with the cheaper option then. i saw att has nokia chargers for $25, or $19 if you buy three. just need to find one of those chip thingies that goes under the battery door.
    10-18-2013 11:08 AM
  1. Wireless Charging
    By john248 in forum Verizon Samsung Galaxy Note 3
    Last Post: 10-23-2013, 07:53 PM
  2. Handwriting Question
    By Cheesewiz in forum Samsung Galaxy Note 3
    Last Post: 10-18-2013, 11:29 AM
  3. New to NFC tags and have a question
    By rjack22 in forum Motorola Droid MAXX
    Last Post: 10-18-2013, 08:53 AM
  4. Battery question
    By jaleesag88 in forum Samsung Galaxy S4
    Last Post: 10-17-2013, 02:48 PM
  5. Mass texting question
    By thomas975 in forum Sprint Photon
    Last Post: 10-17-2013, 12:47 PM
