Originally Posted by
NCARalph Often when I try to use S Voice, it comes back with a no network connection error even though there's either a 4G or WiFi connection. Sometimes after a few minutes it will work, but I've had to restart the phone on occasion to get it to connect. Clearing the data for the app didn't work.
It does appear that if I do something like access a web site from the browser, after that S Voice can get the connection.
You need to have your device rooted and Samsung.
First, download a app like Root Manager or explorer, Idk what exactly its called...
Go to System, hold on to build.prop and touch open in text editor.
Go to the 15th line there it says ro.product.model=Insert the Galaxy S4 Model number, and click menu and Save and exit.
Now, restart your device and your good!
make sure to delete your devices model before you insert the GS4 model.
