Will a battery without the NFC chip allow you to turn it on? If so, how do you test to see if a battery does have it?
I just got a couple of Caseology batteries & the option to turn on NFC does work, but I have no idea if that means it does have an NFC chip. Nothing on the battery says NFC, but I was told the chip is there.
I did do a search & nothing tells me anything in this regard Thanks for any information you can give me
Cheers, Jon
Cheers, Jon
