What I missed going from Razr Maxx to Note 3
Netguysc
Active member
May 22, 2012
27
I only missed one thing and that was the ability to use Smartactions to lower the volume when the phone was being charged.
I know tasker was a solution but I just couldn't figure it out. I discovered automateit in the google store and now I'm not missing my Razr Maxx at all.
I did think the battery life was much lower than the Maxx at first but after using the Note for a week or so the battery has acclimated I guess for now it seems to be equal to what I had on the Maxx, so I have no disappoints with my Note 3 😊
Sent from my SM-N900V using Tapatalk
sux2bu
438
3
I had a RAZR for about a month. Smart Actions is definitly a very cool app. I tried taking off my RAZR and putting it on my S3 but it didn't work. I'll give that Automateit a look.
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
Only thing I'm really missing is the longer battery life.
If I'm not mistaken the battery in the Maxx is only 100 mAh bigger... That isn't going to give any drastic increase in battery.
Sent from my T-Mobile Note 3 using AC Forums.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Tasker has a steep learning curve but once you know how to use it, it is very powerful.
As to battery life, my note 2 and Note 3 gets better battery life than my Droid razr maxx though it could depend on your usage
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
It is not just about battery size, the cpu in the Droid razr maxx is very inefficient compared to the note 3. It was built on a 45 nm chip. Moving to the 28nm chip in the s3 onwards greatly helped battery life.
dragonsamus
972
35
I'm getting longer battery life on the note compared to the RAZR Maxx. Smart actions didn't always work for me but it was a nice idea.
Sent from my SM-N900T using AC Forums mobile app
ccpopham
344
My razr maxx bricked about two weeks ago. Not dropped or anything. Ir just bricked. Smart actions worked some of the time but was not that great. I found an nfc app named trigger on the play store. The pro version has something called fences where when you enter or exit an area you choose events to happen. The fences can cover larger or smaller areas. Pretty great app.
Sent from my SM-N900V using AC Forums mobile app
ccpopham
344
I am so much happier with my note 3 now. My razr was very slow even after resets etc.
MeridianSun
80
I don't miss my RAZR Maxx at all. I gave it to my son to play games on and when he has trouble and brings it to me I like wow I was using this thing?
Sent from my Note 3
