1. Hionimi's Avatar
    Hi, I think the text input when using the S Pen works surprisingly well, and I mean both editors. (There seems to be two, one for when hovering your S Pen over a closed Text Input field and hitting the little Pen Symbol, and one when switching on the Samsung Keyboard itself which summons the full editor, I'm mostly talking about this one.) Now, my only problem with the Written Text Input is how fast you need to write to make it work, sometimes I prefer to write more words at once. For this you need to be quick and have no 'derp?' moments at all. And waiting for the Input to process your word and clear the Input Field then again takes slightly too long to really write quick short messages this way. Thing is, I can't find any settings anywhere in the Settings Menu or the Keyboard Menu at all to change these settings. I guess there is no way to adjust this?
    I suppose if I want to bring this under the attention of Samsung I have to either put this info in a review on the Play store or contact them directly? What do you guys think about the S Pen Text Input?
    11-18-2013 10:01 AM
  2. TheMacs's Avatar
    I love the Spen too, and know what you're talking about. I haven't seen a setting like that, but haven't really looked either. It would be nice, but I'm kinda doubtful it exists. If you find one, post back!
    Cheers.
    11-18-2013 12:24 PM
  3. dafuse's Avatar
    I hare searched for settings and some sort of manual, and found neither. It's really annoying sometimes, and unpredictable. I wish I could at least understand how it works so I could avoid doing something wrong.
    11-18-2013 07:48 PM
  4. Hionimi's Avatar
    Well, what I found so far is that it does do some clever things, like, when you have written a word, it breaks the line a bit. when you write further behind that break you get an automatic Space, but if you put a symbol inside the break you can end or interrupt your sentence with a dot, comma, exclamation mark or question mark. Which works pretty well I must say.
    11-18-2013 08:02 PM
  5. GANote3's Avatar
    I have a note 8 as well and the s pen input for my note 8 is different. It looks like a yellow pad on the bottom and depending on how small you write, ypu can get a few lines in before pausing to clear. If you press the backspace key on my note 8 it will clear the pad and you can continue on. I have not tried it on the note 3 yet.
    Sent from my SM-N900V using AC Forums mobile app
    11-18-2013 08:46 PM
  6. Jason Ricca's Avatar
    Go to Settings>Language & Input. You want the Samsung keyboard by default. There is a settings gear below, adjacent to "Samsung Keyboard". You want the sub menu for Handwriting. Edit the value for recognition time. Cheers! :-)
    12-07-2013 02:06 PM
  7. roguetrader's Avatar
    On my Note 3, there is no handwriting sub menu in the Samsung keyboard settings.
    Sent from my Nexus 7 using AC Forums mobile app
    12-07-2013 04:15 PM
  8. iq160plus's Avatar
    I had this setting with Jelly Bean 4.2. but since the 4.3 Jelly Bean I can no longer figure out how to change recognition time on my GN2.
    anyone else know how?
    01-06-2014 12:14 AM
  1. Samsung Galaxy S4 - Google+ with auto-awesome movie mode
    By dustinfrank in forum Samsung Galaxy S4
    Last Post: 07-02-2014, 03:30 AM
  2. Help Me Choose the Best Android Tablet for the $
    By tess1977 in forum Google Nexus 10 Tablet
    Last Post: 11-18-2013, 10:24 PM
  3. Nexus 7 and Kindle spank the Retina Mini in display quality?
    By JeffDenver in forum General News & Discussion
    Last Post: 11-18-2013, 11:41 AM
  4. Samsung Galaxy S4 Active - skype contacts
    By dlpedersen in forum Samsung Galaxy S4 Active
    Last Post: 11-18-2013, 11:39 AM
  5. Samsung Galaxy Note 3 - S View Cover & Reception
    By sprungson in forum Samsung Galaxy Note 3
    Last Post: 11-18-2013, 11:38 AM
