Heavy user here. Browse. Text. And Facebook for most of the day. I still have 34 percent left. 19 hours 35 minutes on battery.
Sent From My Samsung Note 3 using Tapatalk
Lots of wifi I take it?
Sent from my T-Mobile Note 3 using AC Forums.
Yes!
That explains it.
On mobile data that battery will drop faster. I charge once if not twice at work sometimes... But in all fairness I'm streaming movies, so screen stays on of course, and then I have 3 others tethering to my phone all at the very least streaming music if not Netflix as well . It really rocks the battery.
Yes I'm aware of this. I stream videos and my wifi/data will fluctuate and run off each other if the connection isn't stable so either way, I'm still using some mobile data. I'm almost at 5GB.
That explains it.
Nice. In the past 2 days I've racked up 8 so far. Just started my cycle a little bit ago. I usually average 50-60 GB a month.
I've never noticed the battery life dropping when I've switched from Wifi only to Network only on any of my devices. I start to wonder if people make the assumption that because the Wifi signal is physically closer that it must somehow spare the battery. To me it will depend mostly on the signal's strength and if the device is constantly having to hunt for that signal as to how bad it'll drain the battery. I have yet to see anything that shows one radio significantly drain the battery more than another radio.
That explains it.
He'd still be somewhere around 6-6.5 hours which is still really impressive.
When you use that much does your Internet get very slow off 4G? After 5GB, mine gets to be veeeerrrryyyyyy slow. I have ATT.
First if you mean the other post she has girl in her username .
And also.. You can't say that for sure. I'll post my battery life later after I rock it.
Oh, really? Sorry
Anyway, it wasn't ban exact figure but from personal experience I made an estimate. My best screen on time is 7H 18M, mostly on WiFi. My best on LTE is around 6H 10M
Perhaps I should have spelled it GIRL? LOL. It's too common and thought the system wouldn't take it. So gurl it is. Wouldn't mind being a "he" on some days. Don't think my hubby would like that very much. *inserts evil laugh*
