Save big + get 3 months free! Sign up for ExpressVPN today
12-11-2013 01:48 PM
37 12
tools
  1. boatman1069's Avatar
    Just want to say the note 3 has fantastic battery life..had it since September and im still amazed I can get through my day at work and get home and still use it until bedtime with 30 percent still left. ..wow.
    My galaxy s2 would have used 3 batteries in this time..
    Thanks samsung.
    Sent from my SM-N9005 using AC Forums mobile app
    11-18-2013 02:27 PM
  2. sddabrow's Avatar
    Thanks samsung.
    Can you post your battery stats after a days usage? A lot of us are seeing issues with Google Play Services and Google Now draining battery.. do you use Google Now?
    11-18-2013 02:44 PM
  3. boatman1069's Avatar
    Hope this helps.
    Attached Thumbnails Battery life rocks-1384811441978.jpg   Battery life rocks-1384811518650.jpg
    11-18-2013 03:52 PM
  4. boatman1069's Avatar
    Sorry put up wrong pictures.
    Here are the latest ones
    Attached Thumbnails Battery life rocks-1384811825381.jpg   Battery life rocks-1384811836582.jpg
    11-18-2013 03:57 PM
  5. boatman1069's Avatar
    Sorry....in response to your question I can confirm I don't use google now....
    Maybe this helps battery life.
    I have bought a spare 3rd party battery but as yet had no need to use it . With my galaxy s2 I had 4 spare batteries with me...although I would normally need to put 2 spares in during the day.
    11-18-2013 04:02 PM
  6. Gator352's Avatar
    Gnow and G+ suck battery life.
    11-18-2013 04:19 PM
  7. sddabrow's Avatar
    Thanks. I actually just went into Location > Use Wireless Networks and turned that off along with Google Plus and Google Music. Forecasting 2 days worth of usage now!
    11-18-2013 05:17 PM
  8. zmann's Avatar
    Thanks samsung.
    How did you have it since September? Release day was October 4th
    THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
    11-18-2013 05:49 PM
  9. missdorado26's Avatar
    How do you turn Google stuff off? my battery life sucks
    11-18-2013 11:22 PM
  10. Johnly's Avatar
    My note didn't get charged last night, and I left with 18%. Made it through the day on wifi. Terrific battery.
    Sent from my SM-N900V using Tapatalk
    11-18-2013 11:48 PM
  11. thegame161's Avatar
    the last 3 days i've gotten
    1 day, 3 hours
    1 day, 8 hours
    1 day, 4 hours
    on lighter use but still amazing how much you can get.
    11-19-2013 12:54 AM
  12. boatman1069's Avatar
    Ive been reading others are not experiencing the same as us.... maybe they are doing something different.
    I can truely say this is the first smartphone ive had that I only need to charge at night..
    Truely amazing..
    11-19-2013 03:55 PM
  13. Note 3 user's Avatar
    My battery sometimes drains quite fast as I have on almost everything that can be on. Half an hour ago I tried to optimise everything for long battery life like putting the battery saver on, disabling smart features and so on, and all this time I have been surfing the web - but not lost one single %!
    This just shows that the Note 3 battery is even capable of 50 hours of on-screen time!
    12-05-2013 10:30 AM
  14. Kegman's Avatar
    I have power saving mode turned on and get same results as OP. did you guys turn yours off?
    12-05-2013 08:25 PM
  15. eve6er69's Avatar
    I have power save on and I usually have wifi and gps off unless I am using them. The rest I believe is stock. I get killer battery life.
    Sent from my gameboy color
    12-05-2013 10:45 PM
  16. thegame161's Avatar
    battery life is amazing and whats amazing is when you do run out of juice i love the spare battery option
    my stats from yesterday with auto brightness +5 on
    4 hours, 40 minutes screen time
    17 hours 30 minutes total.
    took it off charger at 5am and didn't need to charge it till 10pm at night
    just what you want for a phone.
    JellyBeanGurl likes this.
    12-06-2013 12:37 AM
  17. thegame161's Avatar
    Two days battery life!! Never had this on any other phone before
    12-10-2013 01:03 PM
  18. JellyBeanGurl's Avatar
    Heavy user here. Browse. Text. And Facebook for most of the day. I still have 34 percent left. 19 hours 35 minutes on battery.
    Sent From My Samsung Note 3 using Tapatalk
    12-10-2013 03:43 PM
  19. anon8126715's Avatar
    I've said it before, and I'll say it again, while the battery life is great, what I like most about the Note 3's battery is how fast it takes a charge.
    12-10-2013 05:10 PM
  20. zmann's Avatar
    I consider myself a heavy user seeing as how I stream non stop all week 9 hours straight per day plus the normal texting, surfing, and any the else. Watch is connected all day plus blutetooh stereo headphones and I never get less than 13 hours. I have 2 spare batteries that I have never used once.
    12-10-2013 05:13 PM
  21. Almeuit's Avatar
    Lots of wifi I take it?
    Sent from my T-Mobile Note 3 using AC Forums.
    12-10-2013 07:36 PM
  22. JellyBeanGurl's Avatar
    Yes!
    12-10-2013 07:42 PM
  23. Almeuit's Avatar
    Yes!
    That explains it.
    On mobile data that battery will drop faster. I charge once if not twice at work sometimes... But in all fairness I'm streaming movies, so screen stays on of course, and then I have 3 others tethering to my phone all at the very least streaming music if not Netflix as well :P. It really rocks the battery.
    12-10-2013 07:47 PM
  24. JellyBeanGurl's Avatar
    That explains it.
    Yes I'm aware of this. I stream videos and my wifi/data will fluctuate and run off each other if the connection isn't stable so either way, I'm still using some mobile data. I'm almost at 5GB.
    12-10-2013 07:52 PM
  25. Almeuit's Avatar
    Nice. In the past 2 days I've racked up 8 so far. Just started my cycle a little bit ago. I usually average 50-60 GB a month.
    UJ95x and JellyBeanGurl like this.
    12-10-2013 07:54 PM
37 12
  1. [GUIDE] Longer Battery Life (or How You're Being Robbed!)
    By realvdc530 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 03-28-2015, 10:40 AM
  2. Battery life after about 2 weeks
    By mchockeyvette27 in forum Google Nexus 5
    Last Post: 12-15-2013, 05:53 PM
  3. Huge battery problems after 4.3 update
    By arkadiush in forum Samsung Galaxy S4
    Last Post: 11-19-2013, 12:53 PM
  4. Replies: 11
    Last Post: 11-18-2013, 08:10 PM
  5. Google Nexus 7 (2013) Mysterious 1013 and battery drain
    By alcathoe in forum Google Nexus 7 Tablet (2013)
    Last Post: 11-17-2013, 11:55 AM
