1. chloeshotmom's Avatar
    I get a sound and when I check my notifications there is nothing there! And sometimes it will chime 3 or 4 times in a row with nothing on the notification.
    Most of the times when I am chatting with line or viber. I ger 2 different sounds. One from the app itself the other one is I don't know where it is coming from.
    i love my note 3
    11-20-2013 03:07 PM
  2. GANote3's Avatar
    When that happens hold your home button down and see what is running. Have you restarted your phone or did a battery pull? Sounds like an app is giving a notification, but something is blocking stopping it fron showing in the bar.
    I woukd start with a battery pull and see if that fixes it. Have you installed any new apps lately? That could have not installed correctly.
    Sent from my SM-N900V using AC Forums mobile app
    11-20-2013 03:17 PM
  3. chloeshotmom's Avatar
    Thanks for the response. I will try to remove the battery and see what happens.
    i love my note 3
    11-20-2013 03:19 PM
  1. Sensor problem
    By EdwardTodorov in forum Samsung Galaxy S4
    Last Post: 11-20-2013, 04:20 PM
  2. Galaxy S3 charging problem
    By maldini3lb in forum General Help and How To
    Last Post: 11-20-2013, 03:57 PM
  3. Sprint Galaxy S3 - Google + Notification Sound
    By captain_dl in forum Sprint Galaxy S III
    Last Post: 11-20-2013, 08:58 AM
  4. Samsung Galaxy S4 - Sound over Bluetooth issues
    By Tom Ribbens in forum Samsung Galaxy S4
    Last Post: 11-20-2013, 07:52 AM
