Snap Dragon Battery Guru On Gnote 3
kca2000
696
147
I have not, but it sounds promising by the reviews. Not that battery life has been an issue, but i might take it for a test drive.
alengman
58
I had it installed on my S4 and now my note3. It seems to help. There is a learning process that takes about 3 days. I can go in and manually set certain apps to only update when I want it to. I like the feature where it turns on and off my wifi based on my location.
benjamminh
1,515
Had it with the droid Maxx for awhile. Once I removed it my battery life improved significantly. Ymmv.
Sent from my XT1080 using AC Forums mobile app
Preach2k
1,967
115
63
I had to uninstall it from my phone. It was draining my battery so fast. I was getting at most almost 2 days at least a day and couple of hours before the app. I let it learn my use. I gave it a week. My battery will drain in 5 hours so it had to go. Now my battery is back to normal. The last few days I have been getting over a day off one charge.
