I had this same problem last week and I tried everything without having to factory wipe the phone (this was a last resort option for me). One of my final steps was to individually uninstall apps I had recently gotten, and checked if it works when the app isn't present. I did it with a couple apps and installed them right after figuring out that they were not the problem, since the issue persisted after uninstalling them. I finally uninstalled the VEVO app and found out that it was the problem. When the VEVO app is uninstalled quick glance worked smoothly. Upon reinstalling the app, the problem was back. So whoever is having this problem and recently updated or installed the VEVO app, I'm pretty sure that's your problem. If not, then we can pretty much assume that the problem is one that arises with some sort of app compatibility issues. I contacted the developers but no response yet. Maybe if others tell them about this problem they will make it priority and fix it in a future update! Hope this helps!
