1. ossamoha's Avatar
    hi ,,
    i have problem in my phone note 3 3g not LTE
    i charge it fully then it starts to discharge quiiiiiickly sooo much , within 3 hours it goes from 100% to 20% without any usage just standby mode with recently formated and 4.3 android software ,
    important note : it continues to discharge quickly even i shut down my phone but if i disconnect the battery the battery stay the same ,,, problem in battery or maybe software ?????
    12-23-2013 12:40 PM
  2. ossamoha's Avatar
    anyone help me ?
    12-23-2013 01:25 PM
  3. kj11's Avatar
    You should download an app such as wakelock detector or something similar to see what the problem is.
    Screen shots and also patience would be helpful if you need some help as well....
    Sent from my SM-N900V using AC Forums mobile app
    12-23-2013 01:45 PM
  4. ossamoha's Avatar
    thx man
    12-23-2013 02:06 PM
  5. Trees's Avatar
    You can go to Settings and then Battery. Battery will show you which apps or OS components are using the battery. As kj11 noted, a wake lock detector can also help if the Battery option does not provide the clues.
    12-23-2013 03:02 PM
  6. ossamoha's Avatar
    OK MAN , thx 4 ur comment
    12-23-2013 03:37 PM
  7. z06mike's Avatar
    Take it to Verizon and get a new phone! That is 1000000% unacceptable. That has to be faulty hardware if you are not doing anything and it is draining that fast.
    12-23-2013 04:16 PM
  8. ossamoha's Avatar
    yea i know but no international warranty
    12-24-2013 08:12 AM
  9. ossamoha's Avatar
    it drain even the my phone is turned off !!!!!
    12-24-2013 08:22 AM
  10. Amir's Avatar
    Then I think battery is faulty.
    Sent from my SM-N9005 using Tapatalk
    12-24-2013 08:57 AM
  11. ossamoha's Avatar
    hope so ,
    cuz i dont prefer to be opened and fixed battery is acceptable
    12-24-2013 09:52 AM
  12. Keerthan Kumar's Avatar
    Even i have the same probelm the batter is getting drained so fast with out using it. Is this problem with my particular phone????
    02-06-2014 04:36 AM
  13. FBA's Avatar
    Never seen a device drain to that extent while it's completely off - something doesn't sound quite right there.
    This may help you, or not...
    http://forums.androidcentral.com/sam...ery-drain.html
    02-06-2014 07:48 PM
  1. HTC One Battery Not Charging/Holding Charge
    By Justin Peeler1 in forum AT&T HTC One
    Last Post: 05-27-2016, 03:59 AM
  2. Note 3 Size Justification - need backup!
    By tannerrblake in forum Samsung Galaxy Note 3
    Last Post: 01-08-2014, 07:38 AM
  3. Motorola Droid MAXX - Battery monitor app?
    By pappy53 in forum Motorola Droid MAXX
    Last Post: 12-28-2013, 06:53 AM
  4. Note 2 will not store media files on SD card
    By Eilea in forum Samsung Galaxy Note 2
    Last Post: 12-24-2013, 01:51 PM
  5. Note 3 Noob
    By artisticsoul79#AC in forum Verizon Samsung Galaxy Note 3
    Last Post: 12-23-2013, 02:50 PM
