You may not be able to answer this, but do you know if the contacts for the S - view chip will interfere with a 3rd party Qi receiver?
It does, I had to remove my qi receiver.
it is actually closed all the way and it's closed pretty tight. I think the gap is to help you open the cover easier,Hey foofoo, in your 7th picture where it shows a side view of the latch, it almost looks like the latch doesn't close all the way? Is this the case?
Sent from my ballin Tab 3 using Tapatalk
Couple issues that I noticed after using it for 2 days. First the contact points to activate the s-view are not perfect. There are times s-view does not activate, I have to press the back of the phone for it to work. Doesn't happen a lot but it does happen, normally right after I remove the case and put it back on. I am guessing it's a fitting issue? Second, I just picked up the phone by it's cover and the cover came off. I was able to snap it back on but it does seem like it's something with wear and tear would create an issue later on.
Reference the S view not activating, is it because the connection points on the back are contacting?
I notice that you have to remove the back cover on the Note 3 and insert the phone right into the rubber housing. Is it a snug fit or is there some play? Does it clip into the rubber as it would clip into the regular cover or the Samsung S View case?
Sorry for asking so many questions. I am trying to decide if I want to order this or the Samsung S view.
Thanks for the help though.
the fit is snuggle but the inner piece which is TPU material, even with a hard plastic cover that clips on pretty tight it still gives that little room where sometimes the contact points are not touching. It is quickly fixed by slightly tapping the back. It was a slight issue but it doesn't bother me much anymore now.
Bad news for this case.... http://www.sammobile.com/2014/01/22...te-3-post-kitkat-update/#.Ut95CjC272g.twitter
Sent from my SM-N900V using AC Forums mobile app
This available in the UK?
