02-17-2014 07:45 PM
42 12
tools
  1. Alain_A's Avatar
    I made this wallpaper using Gimp which is about 6 KB in size. Feel free to use it on your phones.
    Attachment 104231
    Sent from my SM-N900T using Tapatalk
    Doesn't matter what size. I took yours cropped it even smaller like 566 bytes. When I installed it, the phone bumped it up to 34 kb with a resolution of 1080×1920.
    Also I have played with some other pic from my photo gallery. After making it small the phone always bumped it up to anywhere from 34 to 39 kb
    Sent from my SM-N900W8 using AC Forums mobile app
    02-11-2014 03:31 AM
  2. dustrho's Avatar
    Where do you actually see that happening? The image I'm using doesn't appear to have been altered in any way, still show as only being 6 KB in size.
    02-11-2014 06:52 AM
  3. Alain_A's Avatar
    Once you install it to your phone. create a new page without widgets on it then take a picture and look at the details from the gallery or photo.
    The original being in your gallery will always shows 6 KB. Just like mine at 566 bytes.
    02-12-2014 12:03 AM
  4. anon24860's Avatar
    2.2mb here. No widgets but the dock is there. The 2.2 seems to refer only to the shot itself. Doesn't seem to affect my battery life though.
    Sent from my SM-N900V using Tapatalk
    02-12-2014 12:35 AM
  5. Alain_A's Avatar
    http://img.tapatalk.com/d/14/02/12/ezusuded.jpg
    The shot itself should still represent the original.
    I'm thinking unless I think wrong.
    The pic has to cover the entire screen. So probably the screen needs a certain amount of kb to cover it.
    02-12-2014 12:53 AM
  6. anon24860's Avatar
    I'm thinking that the size represents the actual screenshot, not the size of the wallpaper. I still don't know how to tell how big the wallpaper is, but I'm sure it's pretty large since it's large enough to scroll through 5 screens. It's cropped down about half from the original 3.1mb, so I'm guessing it's about 1.5 mb.
    I'm glad it doesn't really affect my phone that much.
    02-12-2014 08:27 AM
  7. dustrho's Avatar
    Well, if we're talking about the file size of the home page after taking a screenshot of it, then mine is 327 KB. I only use 3 screens but will be condensing to just one very soon.
    02-12-2014 08:43 AM
  8. anon24860's Avatar
    So, the size DOES refer to the image, not necessarily the size of the actual screenshot itself. Thanks.
    02-12-2014 09:20 AM
  9. Alain_A's Avatar
    When I took my snapshot of one screen I only had one ( home page ) with a few widget and the second one no widget what so ever.
    Humm interesting to see the home page for hours without widget.
    Today I put a pic from my gallery which is 3.2 mb then charged the phone at 100% and used it as normal. For me only received on call and make 3. After 9.5 hours my phone went down of 14%. I think that's pretty good
    02-12-2014 11:02 PM
  10. Alain_A's Avatar
    Ok removed all widget from home page. Let see what it does. Home page is the only I have right now
    02-12-2014 11:09 PM
  11. Alain_A's Avatar
    According to this something is using wifi while it is turned off. Can't find what it is for now
    Attached Thumbnails Note 3: Interesting discovery regarding battery drain...-1392264659608.jpg
    02-12-2014 11:13 PM
  12. Alain_A's Avatar
    Found this
    Attached Thumbnails Note 3: Interesting discovery regarding battery drain...-1392311107093.jpg
    02-13-2014 12:07 PM
  13. Alain_A's Avatar
    Wifi being off for a few days now and still show active for 3 hrs +
    Attached Thumbnails Note 3: Interesting discovery regarding battery drain...-1392313663152.jpg
    02-13-2014 12:50 PM
  14. Alain_A's Avatar
    Why am i not seeing the last pic?
    02-13-2014 01:23 PM
  15. Alain_A's Avatar
    Hummm
    Attached Thumbnails Note 3: Interesting discovery regarding battery drain...-1392315739215.jpg
    02-13-2014 01:24 PM
  16. FBA's Avatar
    Do you have something that looks for WiFi hotspots and turns it on automatically once it finds one, then turns it off when WiFi is no longer present? I think Google + does that...
    Are you using any type of timed profile that turns mobile data and WiFi on or off depending on time of day? I do, which is why I ask.
    02-17-2014 07:14 PM
  17. Alain_A's Avatar
    tethering and portable wifi hotspot never been turn on from my phone. Now if something would of turn wifi on. wifi icon would of come up???????
    during my trucking week I had tasker to run my sound and bluetooth on and off. still Wi-Fi was always off.
    02-17-2014 07:45 PM
42 12
  1. so what happens when battery dies in two or three years?
    By robbielyn in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 06-22-2014, 10:16 PM
  2. Difference that custom ROM "Beans"has made to my battery life
    By teleburst in forum Samsung Galaxy Note 3
    Last Post: 04-25-2014, 06:25 PM
  3. Internet draining battery
    By Crxssroad in forum Samsung Galaxy Note 3
    Last Post: 02-23-2014, 04:09 AM
  4. Replies: 13
    Last Post: 02-07-2014, 03:52 PM
  5. More lies about battery
    By truthteller10 in forum LG G2
    Last Post: 02-06-2014, 01:33 PM
