Do you leave power saving mode on all the time?
missmawarlina
47
I use the power saving mode all the time. I dont know whether it really saves your battery or not since I never turn it off and compare the difference.
Sent from my SM-N9005 using Tapatalk
anon8380037
5,171
I did early in the day for 2 months. I needed to on my GS2. It dims the screen as the battery gets lower and now I can survive a day without it. I am going to look in to newly downloaded GSAM's power saving when I can be bothered.
Via my Note 3 on AC.
kentuc794
79
Leaving your power saving mode on all the time limits the cpu speed, dims the screen and turns off syncing. So it cripples your phone, I rather carry an extra battery. If you set it to auto at least it won't come on until the battery is at 25%.
Sent from my SAMSUNG-SM-N900A using Tapatalk
shanghaichica
1,112
Never. I want to use my phone to the max so nothing gets switched off apart from Bluetooth when I'm not using it.
Posted from my galaxy note 3
Isc73
111
When it falls below 5% or just whenever I need to conserve battery power
Sent from my SM-N900T using Tapatalk
beh
1,378
16
I am with you on this. What is the sense of paying top dollar for the latest and fastest and then put a 40 mph throttle on it. I get 14 to 16 hours per day with standard battery and full power settings and carry a spare battery for backup.
- - - Updated - - -
i leave mine on unless im downloading movies on the phone. they download faster if the power saver isnt on.
Again, I am with you on this.
JellyBeanGurl
460
It's useless IMO. It comes on at 20-25 percent? I might as well turn it on when it's about 25 percent rather than just leaving it on? I might have to give it a try and see how it is.
missmawarlina
47
How long does your battery last throughout the day?
zmann
3,306
120
I never use it at all. My battery last all day even with heavy use, plus I have 6 batteries anyway. On rare occasions when I don't have enough juice I just pop a fresh one in. I don't get why with removable battery,, battery's are relatively cheap,, why people scrounge for power.
THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
I only turn it on if I really need to save battery and know I won't be near a charger for awhile...
So majority of the time I never turn it on. I also use spare batteries which usually will eliminate the need to use this since I can swap.. Those rare times though I can't.
Sent from my T-Mobile Note 3 using AC Forums.
dkhmwilliams
1,083
I also don't use the power saving mode , but not because I think its useless, but because I really haven't needed to. My phone's battery lasts long enough without the power saving mode enabled.
Sent from thr Note 3...and yeah, its spectacular.
anon24860
693
5
Nope. I do have the screen brightness at about 40% though. Just right for indoors. I crank it up outdoors in bright sunlight.
SirGeorgeKillian
365
18
I bought the zerolemon battery/case. Keep brightness cranked up, and never have a day go by that I can't make it through.
Sent from my SM-N900T using AC Forums mobile app
kerokekerol
