Can anyone recommend an extended battery that's not so "fat"? I'm interested in ones that are the same dimensions as the original battery that came with the phone.
I bought this battery. I've had it for months and it works fine. It does last a bit longer than the standard battery. It is NFC ready. I didn't want to lose the NFC feature when I bought a new battery.
4500mAh NFC Battery F Samsung Galaxy Note 3 N9000 N900V N900A N900T N900P N900R4 | eBay
This was the largest capacity battery I could find that did not require a larger backing on the phone. The Mah is actually 4680 (stamped on my battery).
Can you elaborate more on this?Hey man i recommend not getting an extended batter as they have more MaH it can pottentially damage your phone and battery try power saving mode instead i have a note 3 and can get 18hrs of use with my galaxy gear connected
