1. thegame161's Avatar
    Just makes no sense. Can't quite work why it's using so much.
    06-20-2014 03:51 PM
  2. Almeuit's Avatar
    Try a reboot and see if it helps for tomorrow. Might be a wake lock issue.
    Sent from my T-Mobile Note 3 using AC Forums.
    Aquila likes this.
    06-20-2014 07:42 PM
  3. z06mike's Avatar
    You're on track to get ~5 hrs screen on time. That's pretty good if you ask me. If your screen on time were a lot less then I would be worried.
    Sent from my SM-N900V using Tapatalk
    06-20-2014 10:20 PM
  4. thegame161's Avatar
    Well I switched wifi and data off when I went to sleep so I'm at
    2 hours, 5 Mins screen time
    15 hours total
    With 48% left
    06-21-2014 01:10 AM
  5. z06mike's Avatar
    Do you have location settings turned on? Google Now? Wifi always scanning?
    06-21-2014 12:36 PM
  1. Replies: 61
    Last Post: 06-01-2019, 12:52 PM
  2. Verizon Galaxy S3 - How can I return to stock?
    By tsawrie in forum Verizon Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 08-28-2015, 08:38 AM
  3. Replies: 30
    Last Post: 01-11-2015, 07:59 PM
  4. Replies: 2
    Last Post: 07-09-2014, 07:48 PM
  5. Do any of you encrypt your Notes?
    By Rubus Roo in forum Samsung Galaxy Note 3
    Last Post: 06-20-2014, 09:14 PM
