1. Sweeet1102's Avatar
    Hi, since fews weeks, i notice my to drain battery faster then before.
    When a look on the battery stat, my Android System is always on the top... One of my friend also have a Note 3, and is Android System never go higher then 17%, my mine always around 30%...
    I done a factory reset fews days ago, but not better...
    Someone can help ?
    09-23-2014 08:17 AM
  2. B. Diddy's Avatar
    The percentages don't always tell the whole story. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    09-23-2014 11:11 AM
  3. Sweeet1102's Avatar
    After charging it fully and now at ~60% this afternoon.
    I done nothing special with my phone, Facebook, Browsing a bit and couple of picture. On Wifi 99% of the time.
    When the is in sleep, not battery drain, but when i use it, it seem the drain faster then it should..
    09-23-2014 05:14 PM
  4. B. Diddy's Avatar
    See how it does if you boot into Safe Mode. It may be that something you reinstalled right after the factory reset could be contributing. Safe Mode temporarily disables all 3rd party apps, which can help to troubleshoot: Power the Device Up in Safe Mode - Samsung Galaxy Note® 3
    If you have an SD card inserted, try removing it (making sure to Unmount it first in Settings>Storage). If the card has some corrupt files, that can make the system work a little harder at scanning it.
    09-23-2014 07:24 PM
  5. Sweeet1102's Avatar
    I will try the safe mode. Can i use the phone all day in this mode ?
    09-24-2014 07:18 AM
  6. B. Diddy's Avatar
    Yes--you just won't be able to use any of the 3rd party apps you installed. You can get out of Safe Mode by rebooting the phone again. Sometimes you have to power down first, then remove the battery for 10 seconds, then reinsert it and power on again.
    09-24-2014 10:12 AM
  1. Android Wear Phone app is eating battery
    By RussST24 in forum Android Wear / Wear OS
    Last Post: 12-11-2014, 10:12 AM
  2. s4 wifi(shows on) drains battery
    By Shawaiz Hafeez in forum Ask a Question
    Last Post: 10-01-2014, 01:31 PM
  3. Replies: 2
    Last Post: 09-23-2014, 09:09 AM
  4. note 3 neo
    Last Post: 09-23-2014, 07:51 AM
