1. MS3GT's Avatar
    Probably a million posts about this but, WHATS UP WITH THE BATTERY on this thing? It freakin sucks lately. I swear Samsung does this crap on purpose. Just in time for the new Note.
    I am Aquaman!
    10-08-2014 08:14 PM
  2. Golfdriver97's Avatar
    Can you post some screenshots if the battery stats, please?
    Sent from an AOSP M8
    10-08-2014 08:21 PM
  3. MS3GT's Avatar
    Here are the screenshots after just 1 hour off the charger. I made a 5 min phonecall using MagicJack. This sucks. I just factory reset this thing last week. And pulled the battery and SD card for an hour yesterday. Disabled those carrier apps. I'm using NOVA launcher. I don't know what else to do. I've tried so many other things. I'm really considering throwing this phone and this damn Gear 2 Neo right back in their face. Not to mention these crappy updates they've been throwing our way. Samsung has gotten lazy and too comfortable. That is why they are going to start sinking soon.
    I am Aquaman!
    Attached Thumbnails Battery drain.-screenshot_2014-10-09-11-07-52.jpg   Battery drain.-screenshot_2014-10-09-11-08-01.jpg
    10-08-2014 10:13 PM
  4. Golfdriver97's Avatar
    I am Aquaman!
    Sorry about the delay. Do you have an SD card in the device? If so, try unmounting it and see if that makes a difference.
    10-09-2014 04:36 PM
  5. MS3GT's Avatar
    I have tried that several times as well. Most days this thing is a hog. There are a very few days that it actually lasts a while.
    I am Aquaman!
    10-10-2014 09:20 AM
  6. clevin's Avatar
    10-10-2014 09:26 AM
  7. Golfdriver97's Avatar
    Aside from clearing the cache in recovery, I am not sure what else to suggest.
    10-10-2014 09:31 AM
  8. Closingracer's Avatar
    Seriously this device is only 6 months old and already done factory resets 4 times. If this is what like on the note 4 I'll go to Apple or the LG g3
    Sent from my SM-N900T using Tapatalk
    MS3GT likes this.
    10-10-2014 12:32 PM
  9. clevin's Avatar
    http://tapatalk.imageshack.com/v2/14...8d7d2bc0a0.jpghttp://tapatalk.imageshack.com/v2/14...9e3dc2d241.jpg
    As much as I hate to say it, IP6 will be better than LGG3 in this regard. Google is throwing in too many junks that are massive battery hogs into android with each new version.
    With that being said, my phone last days with no sync, data off when not in use, and google spy apps disabled.
    10-10-2014 03:23 PM
  10. Closingracer's Avatar
    Really has gone down the drain. Only after 6 months
    10-12-2014 06:38 PM
  11. vannylugo's Avatar
    Try doing a battery recalibration by going from 100% to 14% then fully charge from 100% to 80% fully charge. Completly drain you battery and leave it overnight that should do it if no download DU battery.
    If you need help contact me.
    10-12-2014 08:15 PM
  1. Getting bad battery life on Moto 360
    By Afterlife737 in forum Moto 360
    Last Post: 12-31-2014, 03:37 PM
  2. Android System/Android OS killing my batteries
    By UN4GTBL in forum Legacy Android & Other OS's
    Last Post: 10-08-2014, 10:05 PM
  3. Why is the mediaserver on my Note 3 is eating my battery?
    Last Post: 10-08-2014, 05:03 PM
  4. Why does my Samsung S4 die at between 70- 80% battery charge?
    Last Post: 10-08-2014, 04:40 PM
  5. Why isn't my Nexus 4 working after a battery change?
    By majorgowen in forum Google Nexus 4
    Last Post: 10-08-2014, 05:48 AM
