I have an SM-N9004 with Android 4.3 on Australia's Telstra network.
My work requires me to keep contact info on my clients who I either contact via phone or text on my Note 3, or via email using Outlook on my Windows 7 PC.
When I had my Note 2 and Windows XP PC, I used to synch my contacts between them using Samsung's inbuilt app (can't remember what it's called) but after a software update it wouldn't work properly.
I'm thinking back to the days when my old Blackberry had an easy to use synching system - connect the phone to a PC via USB and synching was fast & simple.
Does anyone know an app that allows synching of contacts between my Note 3 & Outlook on my PC, using a USB cable only? (I currently have internet disabled on my phone to keep costs down).
Any advice would be appreciated.
Thanks
... John
10-16-2014 06:13 PM
