Save big + get 3 months free! Sign up for ExpressVPN today
  1. brian17104's Avatar
    I bought a galaxy not 3 like a week ago online I cant change the lock screen it does not even have an option to it just has an option to change the home screen its really making me mad any ideas on what I should do I would screen shot you a pic of my lock screen option but I can't figure out how to put a pic on this formue ether if someone can help me with that to that be great
    11-05-2014 10:53 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! What do you want to change about the lockscreen? Are you trying to change the lockscreen wallpaper, or the actual screenlock method?
    Here's how to post screenshots: http://forums.androidcentral.com/amb...d-central.html
    11-06-2014 02:41 AM
  3. lterry913's Avatar
    Do you have your work account on your phone? Sometimes they are secured a different way and won't let you mess with lock screen. Is there an app that is overriding lock screen in developer options?
    The way I change is to go to settings, display, wallpaper, lockscreen and select where you want to get image from.
    or go to gallery select an image, press menu,scroll down to set as, press what you choose to set image as.
    If this isn't working you may have a security setting being overridden by an app or developer option setting.
    11-06-2014 09:20 AM
  4. Gbsa's Avatar
    My lock screen was stuck on pin unlock and the only options I had were pin or password unlock every other option was greyed out. Found the fix on another forum, go to settings , then security scroll all the way to the bottom and clear all credentials. Now all options are once again open to me
    B. Diddy likes this.
    11-06-2014 09:28 AM
  1. iPhone user considering Nexus 6, need opinion
    By mamutarka in forum Google Nexus 6
    Last Post: 12-06-2014, 09:06 PM
  2. Can someone help me with photo backups and google?
    By agdodge4x4 in forum Ask a Question
    Last Post: 11-06-2014, 12:35 AM
  3. Replies: 1
    Last Post: 11-05-2014, 03:38 PM
  4. Battery Life Help
    By Parafly9 in forum Samsung Galaxy S4
    Last Post: 11-05-2014, 03:07 PM
  5. Can anyone help me get my HTC One SV out of a boot loop?
    Last Post: 11-05-2014, 12:22 PM
