1. masaga91's Avatar
    Hi guys, my girlfriend's note 3 has had a bad battery life since the day she bought it.
    She gets less than 20 hours per charge, and a SOT less than 3 hours, I always thought that was because of the 4.4.2 battery bug, but other people that I know that also have the phone have better battery life
    Anyone have an idea of how to fix it
    *take in consideration that those 18 hours include like 7 of her sleep hours*
    Attached Thumbnails note 3 bad battery life-10580.jpg   note 3 bad battery life-10579.jpg   note 3 bad battery life-10578.jpg   note 3 bad battery life-10577.jpg
    11-21-2014 04:17 PM
  2. AlfieBriggs's Avatar
    Does she always have signal
    Posted via my Note 3 running KitKat 4.4.2
    11-21-2014 04:20 PM
  3. masaga91's Avatar
    Yes she does
    11-21-2014 08:58 PM
  4. 4runnerbrett's Avatar
    Its kind of hard to say from what you posted. Nothing looks abnormal. Maybe buy a new battery and see if that helps. They are pretty cheap and would be something to rule out
    11-21-2014 11:22 PM
  5. masaga91's Avatar
    Normal? She unplugs the phone and in 4 minutes is at 98, and the normal battery life is around 15 hours, is that normal??? She's not a heavy user
    11-22-2014 01:49 AM
  6. masaga91's Avatar
    The battery went from 100 to 5 in 18 hours, that 23 was after a few minutes of charging, and she was sleeping for half of the time
    11-22-2014 01:51 AM
  7. 4runnerbrett's Avatar
    Well from the info you showed no one will be able to help you but try and download battery doctor and get some more in depth stuff will help. My note 3 can get anywhere from 1-2 days
    11-22-2014 04:54 AM
  8. CehowardNote7's Avatar
    IMO, this should be a no-brainer!
    The Note 3, has a removable battery.
    When I had my Note 3, I had TWO spare batteries, and always had a least one with me. Never a problem with battery. That is the PURPOSE of having a removable battery.
    Ditto for my Note 4, I have two spare batteries, that are only used when I get below 25% and I am not stationary. The swap out is 10 seconds..
    Just my two cents...
    11-23-2014 07:18 AM
  1. What model is the unlocked international Note 4?
    By ACGuest in forum Samsung Galaxy Note 4
    Last Post: 11-23-2014, 06:14 AM
  2. Battery % without bringing down quick settings?
    By garrim85 in forum Google Nexus 6
    Last Post: 11-22-2014, 12:25 PM
  3. note 3 4.4.4 and lollipop update
    By masaga91 in forum Samsung Galaxy Note 3
    Last Post: 11-21-2014, 05:00 PM
  4. Excessive Battery Drain
    By Nuno Leonardo in forum Sony Xperia Z1 Compact
    Last Post: 11-21-2014, 02:55 PM
  5. Replies: 0
    Last Post: 11-21-2014, 02:15 PM
