1. komobu's Avatar
    Hi;
    I am looking for the best way to hook up my Note 3 to my computer / external monitor. I would like to manage files with my pc keyboard and pc mouse. What is the best way to accomplish this? I was looking at a video of the Samsung Smart Dock, but I think I saw with the update that the video might have went away.
    With my pc at work I have a dell lattitude plugged in to a replicator with a dual monitor out. It would be nice to now attach the monitor and keyboard and mouse to a kvm switch where I could have a smart doc or similar device on my work station. Then I could hit the kvm switch and send either the laptop or the note 3 to the external monitor and have the keyboard and mouse work with what ever is selected.
    If you have any experience with this type of set up, I would appreciate any feedback
    Thanks Again
    12-15-2014 08:49 PM
  2. jpr's Avatar
    Well before you go buying any hardware, try SideSync. It's very easy to use your computer mouse and keyboard with that app.
    And you can set your laptop display to extended and drag the phone display onto your external monitor if you like.
    kentuc794 likes this.
    12-15-2014 09:22 PM
  3. gozirra's Avatar
    You can go with Bluetooth, or even go oldschool and get an OTG cable and connect directly. I have this one and it can do mice, keyboards, thumbdrives, etc.
    Samsung Micro USB to USB Adapter - Android USB Cables - ShopAndroid
    For video you can also go software or hardware, here's the cable solution.
    Samsung Micro USB to HDMI MHL 2.0 HDTV Smart Adapter - Android Audio & Video - ShopAndroid
    12-15-2014 09:30 PM
  1. Replies: 5
    Last Post: 01-13-2015, 08:39 PM
  2. Note 4 screen flickers and half the screen is shaded
    By Morganz187 in forum Samsung Galaxy Note 4 Accessories
    Last Post: 01-06-2015, 03:50 PM
  3. Why does my moms contact number show her email address?
    By Nicholas Catalanotto in forum Samsung Galaxy S3
    Last Post: 12-16-2014, 06:46 AM
  4. Galaxy Note 3 wont vibrate
    By Jennifer Kilburn in forum AT&T Samsung Galaxy Note 3
    Last Post: 12-15-2014, 09:41 PM
  5. Replies: 1
    Last Post: 12-15-2014, 09:39 PM
