1. Herkfe's Avatar
    Having problems with a few apps and my gallery after the 4.4.4 update. Anyone else? Does anyone know if the update installed "runtime ART" ?
    12-19-2014 07:40 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! You can see if ART is available by going to Settings>Developer Options and look for a Runtime option. If it isn't there, then you're still stuck with Dalvik.
    Have you tried wiping the system cache partition? This can help with various issues after a system update: https://support.t-mobile.com/docs/DOC-11017
    12-19-2014 09:47 PM
  1. 5.0.1 update will not install - incorrect release keys?
    By dudleynascar in forum Nexus 5 Rooting, ROMs, & Hacks
    Last Post: 08-25-2015, 01:03 PM
  2. "No Sim Found: after updating to 4.4.4 on my Verizon Note 3 helllllllllp.
    By Arias83 in forum Verizon Samsung Galaxy Note 3
    Last Post: 01-07-2015, 10:18 AM
  3. Replies: 4
    Last Post: 12-22-2014, 04:32 PM
  4. Replies: 6
    Last Post: 12-21-2014, 02:40 PM
  5. 4.4.4. Manual Update
    By TouchPerception in forum AT&T LG G2
    Last Post: 12-19-2014, 07:39 PM
