Sure.
Some of these may be defaults, I really wasn't paying attention when I first installed it.
0. Plug in your wired headset.
1. Buy Pro version - you will eventually probably need to do this, although initially all Pro features are enabled for testing. I didn't mess with this.
2. SoundAbout Service - On - Auto Restart
3. Media Audio - Wired Headset (with Mic) - I used the earbuds with built in mic that came with my S3 a few years ago, because they were available - feel free to pick whatever is appropriate in your case.
4. Phone Call Audio - Wired Headset (with Mic) - again, my buds have a mic.
5 & 6. Text To Speech Behavior, and Notification Behavior - I didn't change anything.
7. Wired Headset Behavior - Wired Headset Detection (checked), Wired Headset Microphone (checked).
With these settings, when I have the wired earbuds plugged in, incoming call is rerouted to earbuds, does not emit sound from phone speaker. Phone audio occurs in earbuds, earbud's built in mic transmits phone call outgoing audio.
Again, I'm on an SM-N900V.07 (Verizon Note 3) running OS 4.4.4 (stock) build KTU84P.N900V_4.4.4_0033, not rooted.
If you have any other apps/hacks that you have done that could affect audio (such as hacking conf files) this could interfere with the method that this particular app uses. I say that because I am 100% stock and not rooted.
Good luck!
