1. dPvPanda's Avatar
    Hi guys,
    I accidentally spilled water on the lower half of my galaxy note 3. When I wiped the water off and the phone seems to work fine, some water did get into the phone via stylus pen slot. now it won't charge or connect to the computer. When I get it to charge, it is slow. And when I use the phone it sometimes thing I'm attempting to share battery with other phone. Is there some way to fix it? I read somewhere that I should submerge it in isopropyl alcohol 99%, or just use some on the components' connectors. Does any of these two methods work? Is there any better way? And maybe cheaper than finding a professional phone repair guy?
    Best regards
    Panda
    12-28-2014 08:29 AM
  2. Golfdriver97's Avatar
    Welcome to the forums.
    Those might work, but the downside is water damage can spread. Right now, it seems localized to the USB port, but a month or two down the road, this or that might crop up.
    Do you have insurance on the device?
    12-28-2014 09:04 AM
  3. mcg3745's Avatar
    Im not sure I would submerge it in anything other than, maybe rice. Sometimes, without use and with the battery removed, the phone will dry out and function normally. Liquid causes electrical shorts until it is dry. The damage can happen from trying to use certain parts of the phone while the liquid is still inside.
    Yes, I Note.
    12-28-2014 09:37 AM
  4. dPvPanda's Avatar
    can't I sadly don't have a reserve phone..
    12-28-2014 10:10 AM
  5. dPvPanda's Avatar
    Nop.. didnt think I would do something this stupid...
    12-28-2014 10:11 AM
  6. mcg3745's Avatar
    Battery removal and lay it on a heat vent for an hour or two might be enough to let you know what you are working with.
    Yes, I Note.
    12-28-2014 10:15 AM
  7. dPvPanda's Avatar
    Thanks guys!
    12-28-2014 11:12 AM
  1. get rid of empty pages in main screen
    By zivshosh in forum Samsung Galaxy Tab 2 10.1
    Last Post: 05-19-2016, 07:35 AM
  2. Nexus 5 Stuck on Google logo after putting lollipop
    By Gursahib Singh in forum Google Nexus 5
    Last Post: 02-21-2015, 10:56 AM
  3. Number of windows has reached maximum. Cannot open new window.
    By petercohen in forum Samsung Galaxy Note Pro 12.2
    Last Post: 12-28-2014, 11:22 PM
  4. Think phone might have some form of spyware?
    By cherrypie556 in forum Samsung Galaxy S5
    Last Post: 12-28-2014, 06:14 PM
  5. Why won't my Pc detect my Samsung Galaxy S5?
    By TheMassDestructer in forum Samsung Galaxy S5
    Last Post: 12-28-2014, 09:22 AM
