1. Appz-'s Avatar
    Hey guys,
    Since today i noticed after samsung apps updates (i cant remember which ones), my phone connects to my charger but it actually doesnt charge. It also keeps connting to a dock while i dont even own one and keeps disconnecting and connecting. Also with phone turned off or pulling out battery for some time doesnt work. Anyone else with the same problem and/or a solution?? Cheers!
    02-13-2015 06:33 AM
  2. clevin's Avatar
    Probably need more info.
    How old is the phone?
    Using the official charger?
    Connected to wall charger directly, or wireless, or to a computer?
    You can check app info and uninstall app updates and see if that helps
    @T-Mobile GN3
    02-13-2015 06:48 AM
  3. Appz-'s Avatar
    Thanks for replying! Have the phone for 13 months orso, using the official charger. normally connected through wall but also connected with computer to be sure.
    Read multiple problems relating to this but nobody had a solution. also dont know what app caused this..
    02-13-2015 07:28 AM
  4. Chuckcell's Avatar
    Isn't there a list of apps that have (and when) been applied?
    02-13-2015 09:59 AM
  5. Dustin6707's Avatar
    Had this issue a few weeks back. It turned out to be the charging cable for me. Blow your charging port out, with compressed air, there could be lint or dirt in the port.
    02-13-2015 04:48 PM
  1. Serious issue with Messenger
    By Petros DIMITRIOU in forum Google Nexus 9
    Last Post: 02-18-2015, 07:39 PM
  2. How do I fix the M4a format on voice recorder?
    By Didie Dantoni in forum Samsung Galaxy S4
    Last Post: 02-13-2015, 08:06 AM
  3. smart cleaning issue
    By Neil Smith5 in forum LG G3
    Last Post: 02-13-2015, 06:08 AM
  4. How do I sync my photos from Facebook to gallery?
    Last Post: 02-13-2015, 05:52 AM
