1. emad1995's Avatar
    So for the last couple of months I've been noticing that the pictures I take with the front camera are really grainy. After close inspection I noticed that there is dust on the other side of the glass in my front facing camera, and when I say dust old don't mean a few specs, Ita completely filled. Is there any way I can clean off this dust?
    02-27-2015 10:58 AM
  2. SpookDroid's Avatar
    Only by opening your phone. I'm guessing at some point something cracked open just enough to let lint and dust in (I've seen it happen a lot on Nokia devices, especially). You can try blowing compressed air into the device (while it's off and battery removed) through as many openings as you can find and see if the dust seems to move. If not, the only way would be to open the device, removing the lens, and cleaning it.
    02-27-2015 11:21 AM
  3. B. Diddy's Avatar
    How old is the phone--is it still under warranty?
    02-27-2015 11:34 AM
  4. emad1995's Avatar
    The phone is just over a year old so warranty ran out recently :/ I think it may be because I had dropped my phone and there's a small dent in the top right corner on the chrome bezel. It doesn't look like dust would get inside from that though
    02-27-2015 01:46 PM
  1. Can I use Google play apps in my classroom?
    Last Post: 03-05-2015, 08:43 AM
  2. List Apps in Date Order of Install
    By AnnDroid in forum Legacy Android & Other OS's
    Last Post: 03-02-2015, 09:11 AM
  3. How do I plug in the charger on my Samsung Galaxy S5?
    Last Post: 02-27-2015, 07:57 PM
  4. Replies: 1
    Last Post: 02-27-2015, 12:10 PM
  5. Why has my HTC Desire S camera stopped working?
    Last Post: 02-27-2015, 08:32 AM
