1. trooper_dan07's Avatar
    Trooper_dan07
    04-11-2015 07:45 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! What do you mean by blank out? Does the battery otherwise work normally?
    Moved this thread to the Note 3 forum.
    04-12-2015 01:50 AM
  3. trooper_dan07's Avatar
    I mean I was running a battery test to find out if my battery need changing. When I start the test I had 75% batt life 15 min after the phone blank out with about 35 % the longest time my batt last 4-5 hrs minimum used
    04-12-2015 05:19 AM
  4. B. Diddy's Avatar
    So it went from 75% to 35% in 15 minutes, then the phone shut off? Sounds like a bad battery. Can you try a new one or borrow a friend's battery to test out as well?
    04-12-2015 11:11 PM
  5. trooper_dan07's Avatar
    I have an extra battery that come with my phone but can't believe I jus had dis phone like 2mons an a bad battery already smh
    04-13-2015 04:36 AM
  6. B. Diddy's Avatar
    Some batteries can just be defective. Does the other one work normally?
    04-13-2015 10:09 AM
  7. trooper_dan07's Avatar
    Honestly I don't know as yet cuz I never tried it I'm going to and see
    04-13-2015 12:04 PM
  1. How do I turn off screen reader on my Gear 2 watch?
    By AC Question in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 06-12-2016, 09:29 AM
  2. Which one is a better option between note pro and tab S?
    By Osama007 in forum More Samsung Tablets
    Last Post: 04-12-2015, 02:01 AM
  3. I recently have an 5.0.1 lollipop update for my Note Edge.
    Last Post: 04-12-2015, 01:59 AM
  4. How do i turn my phone back on?
    Last Post: 04-12-2015, 01:55 AM
  5. Problem with apps that need MENU buton on LG G3 S
    Last Post: 04-12-2015, 01:53 AM
