1. fisherri's Avatar
    I replaced the charging port on my Note 3 today; easy peesy, but not my screen won't turn on. The phone powers on, but nothing on the screen. It is such a simple procedure; I don't understand what could have happened. I haven't put the screws back in yet; but in the video, he checked his before putting them back in, and it came on just fine, so it doesn't haven anything to do with that. I'm at a loss!!
    04-13-2015 03:50 PM
  2. Kevin OQuinn's Avatar
    Well, you had to do something wrong or it would be working.
    Double check all connections.
    (Not as easy peesy as it seemed, huh?)
    04-13-2015 04:34 PM
  3. fisherri's Avatar
    I figured it out for future reference for anyone else... I had accidentally loosened the LCD wire. very happy now!!
    Kevin OQuinn likes this.
    04-13-2015 05:02 PM
  4. fisherri's Avatar
    I figured it out for future reference for anyone else... I had accidentally loosened the LCD wire. 😃 very happy now!!
    04-13-2015 05:02 PM
  5. Richie7740's Avatar
    I just had the same problem happen to me just now. Where exactly is the LCD wire located in relation to the layout of the Note 3 back panel?
    04-28-2015 02:58 AM
  1. Disable Annoying Beep sound on Volume change.
    By Subscriber360 in forum Legacy Android & Other OS's
    Last Post: 05-17-2018, 02:07 AM
  2. Phone is not charging
    By S Kess in forum Ask a Question
    Last Post: 04-16-2015, 03:16 AM
  3. How can I forward a thread on my Moto MAXX (Android)?
    By Carolyn Scott-Marks in forum Motorola Droid MAXX
    Last Post: 04-14-2015, 11:01 AM
  4. Replies: 1
    Last Post: 04-13-2015, 06:46 PM
  5. Is my phone fixable?
    By AC Question in forum Motorola Android Phones
    Last Post: 04-13-2015, 03:26 PM
