1. AC Question's Avatar
    After a recent software update the battery goes nearly dead with very little use.
    Thank you for any help or comments.
    04-21-2015 10:26 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Was it a system update? Which Android version is the phone on?
    Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    04-22-2015 12:04 AM
  1. Replies: 3
    Last Post: 04-22-2015, 11:37 PM
  2. Replies: 1
    Last Post: 04-22-2015, 08:55 AM
  3. Replies: 1
    Last Post: 04-22-2015, 12:05 AM
  4. Replies: 0
    Last Post: 04-21-2015, 09:22 PM
