Note 3 S Pen Hover Air command doesn't work..
On Kitkat 4.4.2 was working fine for my Note 3, use S pen for air command, etc, everything is fine.. Until I got update new firmware Lollipop 5.0.. It's doesn't work anything.. No hover air command when use S pen button.. Nothin..
I did check under all settings off then back on.. Nothin work..
I did reset factory and delete caches under boot..
I cannot find anything to fix it..
I'm not sure Lollipop have bug?
My device is..
T mobile Samsung Galaxy Note 3
Android
Lollipop 5.0
Re: Note 3 S Pen Hover Air command doesn't work..
I mean, when i pull out s pen from Note 3, it does appear air command menu .. But when I need air command, I tried press button S pen, it doesn't respond anything, no air command..
Thanks
Assuming you had the pen close enough to the screen when you pressed the button (and you didn't have another pen in the phone - that messes things up), bring the phone into Best Buy, find the Samsung rep (in the cellphone area - look for the blue shirt with the Samsung emblem over the left pocket area), and ask if they can get it working for you.
Thanks for your time.. I'll go to best buy..
Originally Posted by
surly Same issue for me. S Memo is activated when I pull the pen out, but pressing the button on screen hover or trying to do a screen capture doesn't work after the Lollipop update.
Let us know if the guy at Best Buy can fix it. Might just be a bug.
Try here:
http://forums.androidcentral.com/sho...d.php?t=508401
My co worker who have T moblie Samsung Galaxy Note 3, kitkat 4.4.2, he didn't want update to Lollipop, so I test on his phone to see if something going on.. it's working when I pressing button on screen hover, it appear Air Command menu! On my phone with Lollipop doesnt work!!! Seem like Samsung changed to disable..
