1. Kc Anmol's Avatar
    I have note 3 N900...its just 10 days old....i updated from 4.4 to 5.0 lollipop.
    I heard the note 3 has got awsum battery life but i dont think so....
    I need to charge it at evening after full charge in morning...with wifi almost on the whole time
    Average backup is of 9-10 hours with 20-30% battery remaining
    I dont have heavy apps....
    Yes my use is a lil heavy like watsap messngr chrome etc but atleast i shud get a backup of 15-20 hours
    On 3200Mah battery....
    CheckNote 3 Battery drain...-screenshot_2015-05-03-13-18-29.jpg in screenshot...
    It used 50% in just app. 4hrs....
    Plz help
    05-03-2015 03:49 AM
  2. jpr's Avatar
    Well you have over 3 hours of screen on time so that seems pretty normal to me. You're on track for over 6 hours SOT. You can lower the brightness on your display and shut off any apps you don't use and sync apps less frequently, etc, if you want to save more battery, but you shouldn't expect 15 hours of screen on time no matter what you do.
    Elvin Pena likes this.
    05-03-2015 04:49 AM
  3. Kc Anmol's Avatar
    Hmm actually the thing is...earlier i had grand2
    And i used that phone too in the same amount....
    I see no dffrnce betweek backups of both the phones....that has 2600mah
    This has 3200mah....atleast there shud be a dffrnce
    05-03-2015 01:26 PM
  4. jpr's Avatar
    The Grand 2 has a smaller display, lower resolution, weaker processor, and I could go on. You should not be comparing these two phones for battery life. The Note 3 needs much more power, which is why it has a higher capacity battery. Btw, one of the joys of having a phone with a replaceable battery is not having to obsess over things like this. You're getting reasonable battery life and if you need more, just get a spare battery.
    sarkycow likes this.
    05-03-2015 01:55 PM
  1. Battery draining fast and not charging
    By patchesy in forum Samsung Galaxy S5
    Last Post: 05-03-2015, 03:57 PM
  2. Is mine a lemon? (With battery stat screenshot)
    By maryfanning in forum Samsung Galaxy Tab S 8.4
    Last Post: 05-03-2015, 03:26 AM
  3. How can I get my Note 2 camera working?
    By AC Question in forum Samsung Galaxy Note 2
    Last Post: 05-03-2015, 02:37 AM
  4. S Pen Note 4
    By Anthony Gunby in forum Ask a Question
    Last Post: 05-02-2015, 06:58 PM
