1. gazly's Avatar
    Hi folks,
    I've Note 3 (N9005) which is 1 year old. From earlier this week when I tried to charge my phone with the charger (Original) while phone was switched on it didn't charge at all. Then I switched off the phone and tried to charge the phone then it was charging but in a wired way. I saw following
    1. I saw a Grey Color battery instead of Green Color batter
    2. Phone is vibrating many times (every 1 min)
    Could you please help me to fix?
    Thanks in advance
    05-09-2015 03:49 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! The battery might be failing. Try a new one.
    05-10-2015 02:49 AM
  3. gazly's Avatar
    Hey Thanks for the quick response. BTW I changed the charging port and which cost me around 15 USD now it works fine
    B. Diddy likes this.
    05-10-2015 04:36 AM
  4. B. Diddy's Avatar
    Great! A new battery would've given you the same problem, then, so it's good you did that first!
    05-10-2015 12:52 PM
  1. Replies: 8
    Last Post: 06-22-2016, 02:04 PM
  2. Replies: 8
    Last Post: 05-13-2015, 12:52 PM
  3. Replies: 1
    Last Post: 05-09-2015, 11:40 PM
  4. Edge screen help
    By C5p0 in forum Samsung Galaxy S6 edge
    Last Post: 05-09-2015, 01:43 AM
  5. Replies: 0
    Last Post: 05-09-2015, 01:16 AM
