1. AC Question's Avatar
    I have galaxy note 3 I need to copy the calendar from old note 3 to the replacement note 3
    06-18-2015 08:13 AM
  2. anon8380037's Avatar
    Hello. If you used the Google calendar or the Samsung calendar in the app, you need to set up your new device with the same Google and Samsung accounts.
    These are cloud based calendars.
    Go to Accounts Google and Accounts Samsung, touch the account name and ensure Calendar is synced by default.
    Turn on Master Sync.
    If you used My Calendar, the device only calendar, you can only retrieve those entries if you synced or backed up to Samsung Kies on a pc.
    06-19-2015 02:45 PM
  3. anon8380037's Avatar
    ..... although.....
    If your old device is fully functional, you can backup to Kies, or preferably the newer Samsung Smart Switch program for pc, and Restore to the new device.
    Also sync as much as you can to your Samsung and Google accounts, as Kies and Smart Switch don't make a complete image of your old device.
    06-19-2015 02:52 PM
  1. Recent updates for the note 4
    By doohsun in forum Samsung Galaxy Note 4
    Last Post: 06-18-2015, 11:25 AM
  2. Samsung working on Android 5.1.1 For Galaxy 5
    By captfbgnet in forum Samsung Galaxy S5
    Last Post: 06-18-2015, 10:43 AM
  3. Why can't my Galaxy S4 send SMS through my car anymore?
    Last Post: 06-18-2015, 08:08 AM
  4. Replies: 0
    Last Post: 06-18-2015, 08:02 AM
  5. Replies: 0
    Last Post: 06-18-2015, 07:58 AM
