1. phil19's Avatar
    Hi,
    I know this is a common problem and there are many threads out there but unfortunately no solution has helped me.
    When I plug my Note 3 in the charger, it shows that it is charging but it's actually not.
    I have tried the following:
    - Reset to factory settings
    - changing USB-cables (various normal Micro-USB and 2 USB 3.0-cables)
    - using different chargers (Samsung original charger, Laptop w/ USB 3-ports, various Micro-USB-chargers which charge my older Note 2 perfectly)
    - using different batteries
    - replacing the USB/MIC-Port
    - cleaning all ports on the mainboard
    I only have two ideas left: The mainboard is not working properly or the replaced USB-Port is also faulty.
    Do you have other suggestions?
    Thanks
    Philipp
    08-19-2015 03:24 PM
  1. Looking for a Z3 case that covers magnetic charging port.
    By fatbob73 in forum Sony Xperia Z3
    Last Post: 08-25-2015, 02:19 PM
  2. Best S-Pen Apps for the Note 5
    By Frenzytom in forum Samsung Galaxy Note 5
    Last Post: 08-19-2015, 02:34 PM
  3. Samsung Galaxy Note 5 or S6 Edge+ Always Listening??
    By DotScott1 in forum Ask a Question
  4. Replies: 0
    Last Post: 08-19-2015, 02:14 PM
  5. Replies: 0
    Last Post: 08-19-2015, 02:09 PM
