Hello guys I have note 3and every time want to use used to check balance code run and in few say try again I try many times but same plz can help
Printable View
Welcome to Android Central! Sorry, can you clarify your question? Are you saying that the phone is telling you that you're out of minutes or data on your wireless plan?
Ussd run and then gone and in few pop up and say try again
See if this is helpful: Check Your Data Usage with USSD Codes - VisiHow
Am from Algeria
Mine to does so am in Uganda
