1. Haitham Hemdan's Avatar
    I need your help, i have already samsung galaxy note 3 SM N9005 , it worked very well.
    But,from yesterday i had a problem ,S pen not working suddenly,the phone detect attach and detatch the pen by sound and vibration,but no response to touch nor point marker during hover the pen on screen.
    I tried to made reset factory and flash stock firmware again, but also the problem still existed.
    I tried my pen in another note 3 ,working well with the another phone and the another pen not working with my phone
    Help,plz
    Aymane Zgaoua likes this.
    10-14-2017 06:31 AM
  2. Rukbat's Avatar
    Most likely, the SPen layer of the screen has gone bad, or the parts on the motherboard that connect to that layer have gone bad. (The SPen isn't just a "plastic finger", there's an additional layer in the screen that makes it work.)
    The phone has to go to a repair shop for troubleshooting and, if you want to spend the money, repair. (You may want to buy a good used phone if the repair will be more than the used phone.)
    Fulani Filot likes this.
    10-14-2017 02:42 PM
  3. Fulani Filot's Avatar
    In addition to what Rukbat said, you can also do an SPen test by dialling the following USSD code:
    *#0*#
    This will launch a service menu that looks like the one pictured. Tap the circled (in magenta) option and do the test.
    10-17-2017 02:04 PM
  1. Do touchscreen gloves work with Whitestone?
    By notefreak in forum Samsung Galaxy Note 8
    Last Post: 10-21-2017, 07:47 AM
  2. Where is the clipboard on a ZTE Max Pro? The long press does not work.
    By Android Central Question in forum Other ZTE Android Phones
    Last Post: 10-14-2017, 02:54 PM
  3. why there is a message appearing moisture detected ?
    Last Post: 10-14-2017, 02:52 PM
  4. Replies: 1
    Last Post: 10-14-2017, 05:58 AM
  5. Where is the clipboard on a ZTE Max Pro? The long press does not work.
    Last Post: 10-14-2017, 03:37 AM
